Results 1 to 6 of 6
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Test Pipes without removing DP's?
    So I finally got my piggies done today, but am kind of wishing I had done test pipes as well. Would it be possible to cut the main cats and either weld or clamp in some test pipes with 02 sensor bungs and VAST 02 CELiminators? My big idea would be to clamp in the test pipes when I take it to the track, then clamp the main cats back on for regular daily driving. Would clamps work or would that be a bad idea? Should they be welded in? Can they be welded in with out removing the downpipes?
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Test Pipes without removing DP's?
    I havnt done either test pipes, or piggies yet, but I have seen enough guys have problems with exhaust leaks. To me I think you would have problems with leaks if you tried just clamping them.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Feb 17 2004
    Sterling, VA
    There's just no room in there to do it properly and without carnage to any other parts.
    You really have to remove them.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Quote Originally Posted by Daft View Post
    Thats kind of what I figured...
    B5 S4 6MT Stage 2+
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    i think if you sectioned the exhaust there would be enough slack to cut out the main cats.
    When i was putting in my aftermarket exhaust there seemed like a decent amount room, but i'm forgetful
    Then just code out your ecu for the rear o2 sensors, why screw around with bungs and 02 sensors.
    And just live with your polluting ways, your already burning precious 93 oct
    my .02 cents
    B5 S4 AWE Stage 3 - sold
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    I did my piggies recently and left the main cats. The rear o2's are coded out. But I want to find a way to have test pipes year round, and just swap in the cats for CARB next year, without having to go through all the pain and agony of removing downpipes every time.
    Does anybody know if removing the main cats have any significant gains to merit my effort? I mean, how restrictive can they really be?
    -It's got nothing to do with your vorsprung durch technic, you now.-
