Results 1 to 2 of 2
    Registered Member Two Rings
    Feb 10 2008
    RI
    coolant fan/ thermo switch?
    Hey on my a4 the cooling fan has been stuck on high. Im not sure if its the aux cooling fan or the mechanical. But my guess is just a faulty thermo switch? Could anything else cause this?
    its a 12v
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: coolant fan/ thermo switch?
    Coolant temp switch located on the passenger side bottom radiator.
    Key off > Disconnect it > Key on > if it stops, switch bad.
    Low speed only is also controlled by the CC module via relay located behind drivers kickpanel.
    If you search the A4 archives, you will find more......
