Results 1 to 15 of 15
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Intake "flapper"
    I was searching for something else and came across this post at AW
    "Airbox modification - 2005 model. Sounds better!"
    I have a 05 and never heard about this before, is this pretty common? to keep the flapper open all the time and block the resonator?
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: Intake "flapper"
    That flap opens above 5000 rpm or speeds higher than 200 kph (~100mph) to let more air into the filter box. Audi calls it the Power Flap...
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 22 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Nice diagram, I see the flap that they are talking about keeping open, but where is the resonator that they are blocking?
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    Has anybody tried this? If so, is it a worthy mod?
    Sean
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    It would seem (to a psychology major, with no background in mechanical engineering) that the flapper going away would be a good thing at all times. A bit louder, but hey, nobody here should be the type to fuss about "a bit louder."
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
    Jul 22 2008
    Washington D.C.
    This is the same sorta thing the Vtec Integra GSR engines have. There is a Secondary Butterfly setup in the actual Intake manifold. I wanna say the theory for this has to do with air velocity. I'm sure Audi didnt really care about noise when drawing the S4's airway. Regardless this would be a great mod to test while on a Dyno being as it seems fast enough to do. Anyone getting dyno'd soon wanna try this and report back? I wanna say you may loose power... then again it may end up allowing cooler air in from that front vent. Now I'm curious :)
    Jul 22 2008
    Fed Way, WA
    LOL. VTEC engines engage an entirely different cam profile using secondary lobes actuated by oil pressure...
    I may be a psych major, but I went through school driving a 2001 Prelude that had been modded for track days.
    Jul 22 2008
    Washington D.C.
    Quote Originally Posted by Stormin View Post
    Yes I know that Vtec activates that way but the OBDII GSR engines use a secondary flapper system in the Air intakes. basically uses only half the manifold and then at 5300 RPM the butterfly opens the bottom intake runners allowing more air into the cylinders.
    Jul 22 2008
    Fed Way, WA
    Ah...
    A feature not present on the Prelude, which had just the regular 4 runners. (Though my factory intake manifold lasted all of 14 days before being pulled when the new one arrived, so it would not have mattered.) That had to be an emissions/fuel economy issue?
    Veteran Member Four Rings GFRRS3's Avatar
    Dec 06 2007
    LI NY
    So did any one do this yet and is there any difference in sound or throttle response????
    2017 - AUDI TTS
    2017 - PORSCHE 911 C2
    2019 - VOLVO XC60 R-DESIGN
    2021- AUDI A6 ALLROAD - SOLD
    2020 - AUDI RS3 - SOLD
    2006 - AUDI A3 - SOLD
    2005 - AUDI S4 - SOLD
    2004 - AUDI A4 USP AVANT - SOLD
    1999 - AUDI A4 AVANT GT28RS - SOLD
    IG- Greyfoxresearch
    Oct 11 2007
    Suburbia
    What about the exhaust flapper? I'm curious to know about that too....
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    I took mine out when I installed my Carbonino, and when I went back to the stock air box I just left it out. Cant say that I really noticed anything. Would there really be anything to notice?? except a bit of noise.
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I did this the first few weeks I owned the car. I posted this on A/W
    http://forums.audiworld.com/s4b6/msgs/434430.phtml The A/Wers don't seem to be as mod friendly thinking out side of the box some times. The post had mixed reviews.
    I did test this with Vag Com the result was more a higher MAF value across the board. Was there a difference in power...not really I think the MAF value is good to show the car is getting in more air. But with a stock chip the car is only going to do so much with the extra air.
    ChronicTeutonic chimed in and as in this thread was super helpful. Stating that the car " Audi Training Manual states that the flap opens around 5k rpm on the RS4 to increase airflow " I found this to be true as I Vac tested the line.
    My 02. on this
    We have seen from several people that the stock air box dose quite well for the B6. Audi seems to think that above 5k the box might need some help. So there might be some benefit in having it open all the time. But most likely the benefit will come in above 4k when you are almost out of the Tq range as it is.
    Apr 11 2008
    Pasadena, CA
    Justincredible thanks for doing the tests and letting us know your findings. I forgot to reply back to you on the Audi Factory stuff. It's all available through Robert Bentley's (makers of the Bentley Manuals for a bunch cars) website. I use the eBahn service which includes TSBs and campaign information plus the regular repair materials.
    The Avant Garde
    Jul 24 2008
    chicago
    Quote Originally Posted by ChronicTeutonic View Post
    Thanks you always have such good info on this. I wanted to ask you again but didn't want to be a pest. Thanks for the info I'm going to order the stuff tonight
