Results 1 to 6 of 6
Thread: Octane booster
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Octane booster
    Upgraded to APR Stage 1 today, wanted to get the deal before the end of the month. Now after doing some research and searches I have come to the conclusion that I will more than likely be replacing the DV and possibly the TIP. Is there anything else that might start giving me issue with the added boost?
    Currently I have a new Forge 007 with a green spring new in the box, to replace the stock DV in the case it goes out.
    I have a AWE boost gauge coming will be here Thursday, so I can keep an eye on the boost.
    Trying to decide what TIP to go with. I am prepping the car for a K04 next summer. (K04 and supporting mods will be as high as I take her). I have heard samco and apr make nice replacement TIP’s.
    Now on to the more important discussion. Has anyone run a chipped car on octane booster? Sadly Alaska is horrible in the fact that the highest octane obtainable at the pump is 90. So the shop where I got flashed sells Torco Octane booster. These guys tune everything from trucks to STi’s, EVO’s and vag’s. And say that they have no issues running flashed 93 octane files on the vag’s with octane booster. Anyone have any experience with this. I am currently running in stock mode till my next fill up where I will use the Torco and then kick her into 93 mode and see what happens.
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Re: Octane booster
    i've never heard anyone say anything good about octane booster, there was a link somewhere i found either here or on AW that had all the CONs listed about octane boosters...
    btw, that sucks about only having 90... here in hawaii the highest i've found was 92 :(
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Re: Octane booster
    I can only find 91 octane in Calgary, Canada
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Registered Member Two Rings kyran A4's Avatar
    Feb 25 2008
    04 Quattro A4 1.8T
    Moorpark
    Re: Octane booster
    104 down the street :D
    -2004 silver A4 Quattro 1.8T-
    Debadged | RPM 502 18'' Hypersilver | Dunlop Sportmaxx tires | APR K04 | Audi TT 225 injectors | Magnaflow Exhaust | APR Software | ATP downpipe
    Future:
    Euro Code FMIC
    Tein H Springs
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    Re: Octane booster
    most typical oct boosters suck!
    Torco, ROCKS! On our 1.8t with revo, MBC, 3" turbo back, we bump boost and timing when we go from 91 to torco, which gets us up to about 100oct.
    Torco isn't an octane boost, so much as its a race fuel concentrate. Try it out, its cheap enough to test. Then let us know what you think.
    FWIW, a VW tech drove the car, and said it was one of the fastest stock turbo car he's been in, and that was on the 91 program.
    - Benny
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: Octane booster
    toluene 100% (20% max) or xylene (10% max).
    ^^ your paint supply store (commercial) sells this stuff in 100% purity.
    the difference between 87,89,91,93,100 octane is primarily toluene content in most gasoline formulations.
    plus this and that. toluene is effective 114 octane (octane only goes from 0 to 100).
    xylene is like effective 118 octane.
    they both eat paint so fast its not funny. use a pump. then fill up the tank to swish it up a little.
    gasoline never mixes easily.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
