Results 1 to 14 of 14
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    Exclamation Help, Plug Soaked w/Oil
    Went to change my plugs as they have about 5k on them, and one plug was soaked with oil. The actual electrode was clean, but the prongs and threads were nearly dripping. The torque seemed fine when I loosed the plug. I just had the VAG codes checked two days ago, and there were no codes on that cylinder. I had an intermittent misfire on #4, but this plug was in #2. Causes???
    By the way, the gap was still the same as new, and they showed little wear, so it seems the every 5k change on the triple prong Bosch Super is too soon. Is there something I'm missing?
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Help, Plug Soaked w/Oil
    Prolly not missing anthing, just running rich. need to log with vag-com to see. intermittent misfires can happen. just check to see if they reoccur. Log in a WOT 3rd gear pull (channels 003, 002, 020, 031)
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    btw how does running rich soak the thread plugs in oil, maybe its ur valve cover gasket going out, check the walls where u put in ur igntion oils, maybe oil is creeping in from there through a leaky valve cover gasket.
    good luck.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I'd check the valve cover gasket as well
    Some fast things and some slow things
    ~Josh~
    Feb 12 2004
    Everywhere
    Sorry posted late last night, thought you typed soaked with fuel not soaked with oil, my bad. Yes valve cover gasket is a definite possibility. Take a flash light and shine down that spark plug hole to see what the top of the piston looks like. Hopefully the oil in the cylinder is not blowing by messed up piston rings and getting to the piston top and spark plug. I highly doubt that is the case though...
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Why change a 3-prong every 5k miles? It has three prongs specifically to last much longer. The 5k mileage change is for those single prong copper plugs.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    May 16 2008
    Santa Clarita CA
    I had read here that it was needed, but definitly too soon. In this case it was good, so that I caught the leak. How long should the 3-prong last?
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    sidebar:Which 3 prong do we use for our engines?
    Back on topic: Did you do a compression test?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Feb 12 2004
    Everywhere
    Yeah good call. Compression tests are very easy to do. Sears sells craftsman kits for less than $50. You do though need to pull out 4 engine management fuses on your fuse panel before conducting the test though.
    I don't think it's necessarily the 3 prong vs one prong design of the spark plug....more like that the center electrode used is copper.
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by CO AVANT View Post
    Further sidebar, anyone try the E-code spark plugs? Suppose to deliver a better spark?
    On topic: Compression tests will give you a hint to the internal working, rings, etc. Like you said it's cheap, probably free if you take it to a shop that thinks they will be working on your car. LOL
    USP Member 110
    Feb 12 2004
    Everywhere
    E-code spark plugs? You mean the FR5DTC's they use mostly? They are a good plug. I tested them against many others a few weeks ago under the same conditions... they came out on top.
    http://www.audigeeks.com/forums/index.php?topic=3036.0
    Jun 15 2008
    Fairfield, CA
    No, these:
    http://store.summitracing.com/partde...5&autoview=sku
    I meant to say, E3, not eCodes...had a brain fart...LOL
    USP Member 110
    Feb 12 2004
    Everywhere
    Never even seen those before. Look like a splitfire plug with more prongs. I'm interested to see how they perform but will wait to see how these work for people. I am the type that is scared about a center electrode node breaking off and damaging my engine, thus the reason why I've always stuck with brands like Bosch and NGK over brands like autolite and Champion...
    Jun 15 2008
    Fairfield, CA
    Same here, I'm a skeptic as well. But my friend said that Motorweek featured this and was raving about it. I saw that Pulsar one as well...but having learned my lessons with Splitfire back in the 90's...LOL
    USP Member 110
