I know it's been mentioned in previous threads on displacement increasing, but I'd like to know more.
I know the 2.0 8V blocks and the 1.9L TDI blocks will bolt to our trans. and that all the 4cyl have the same bolt pattern for the F/W's. So, is there an advantage to using the 2.0 or the 1.9? Better metal in one than the other? Easier to run catch can lines, lower cost... ??? Obviously the TDI will not need the grinding to clearance the TDI crank, but I'm not sure I'd want to use that one.
I'm not building an engine real soon, but when I do I'd like to be able to spin 7500rpm+ w/o any issues.
I know there's a mechanical advantage to using a longer connecting rod, has it been done in the 1.8T world? I'm interested more in the longer rods than displacement increasing.
- thanks
