Results 1 to 9 of 9
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Question Throttle Body Sensor on DBW Blew Out... Can it be fixed?
    Hi there,
    My sensor blew on my 2001 A4 1.8T throttle body. Does anyone know if that is a replaceable item or is the throttle body a paper weight now?
    Here are photos of my broken throttle body:
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: Throttle Body Sensor on DBW Blew Out... Can it be fixed?
    I do not know if it came be fixed. Sorry. But if you need to repalce it, go with a bigger one from 034.
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by VTAudiA4 View Post
    Crap, I really hope you're wrong. I was hoping to fix it up and have it as a spare since I bought a new one down at waterfest (when it blew out on me).
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    bba-reman might be able to fix it for you.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Apr 10 2007
    Eastern PA
    I tried bba-reman today. Turns out they only do repairs on the nDBW throttle bodies. The dealership wouldn't give me a replacement part # either. Guess this thing might really be a paper weight.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    I sell them used all the time for ~$50US or so.What exactly is blown?Did you open it?
    Apr 10 2007
    Eastern PA
    I just got finished opening it up and I'm really not sure what blew out to be honest.
    What should I be looking for?
    Here are some pics (click for a larger view):
    Feb 26 2006
    Earth
    Usually the block "cover"" goes bad.Why dont you try cleaning it with a little electrical cleaner and seeing if it will work?
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by Issam@034 View Post
    Bringing this back to life since I finally got around to cleaning and testing out the throttle body.
    Issam, you were right. After cleaning the contacts on the black cover and letting it sit out to make sure everything was dry (there was a lot of humidity when it failed on me at waterfest) I plugged it back in and it worked fine. It also passed the adaptation tests so it looks like it is good to go again.
    That's it, just wanted to post up the solution.
    Thanks guys!
