so my goal of making my car daily driveable on the stock ecu and passing inspection is finally close.. The car runs great, but I'm failing three readiness.
1) Oxygen Sensor(s)
2) Evap
3) Catylitic Converter
So, I'm not running a cat, and I don't have my post-cat o2 in the exhaust, it's just plugged in. My evap system I'm not so sure.. It has always failed since the car was stock. I took the hard line that goes from one side of the bay to the other completely off and plugged both open hoses and the port in the intake mani, still nothing..
Basically, I need the fastest, cheapest way to pass one or more of these remaining readiness blocks. Cars from 1999 and down can fail two readiness and still get an inspection sticker in NY.. None of these things effect my perfromance, so I don't care which is fixed.
Would putting a resistor on the harness that plugs into the weird evap motor/solenoid/sensor be a fix? Or do you think just running the post cat o2 with a defouler would solve my issue.
Any input is appreciated.. I have 10 days to get the new inspection.
