Results 1 to 11 of 11
    Mar 21 2008
    Tools needed for Axel replace
    Comeing from the honda world so i dont have any tools needed for Audis.
    What tools will i need to replace an axel and what are they called exactly so i can go buy them thx
    Dec 06 2007
    Calgary, AB, Canada
    Re: Tools needed for Axel replace
    17mm hex socket, 10mm 12pt socket, torque wrench, floor jack, socket set with extensions.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    14 mm Allen socket for the rear. And a 1/2 drive long handle wrench/breaker bar helps a lot b/c the bolts are very tight.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Dec 06 2007
    Calgary, AB, Canada
    ^^true.
    OP, which axle are you talking about? There are several in the car. There's the front and rear CV axles, the drive axle....
    Dec 03 2007
    Potomac, MD
    Quote Originally Posted by The_Jerbel View Post
    actually its a 12mm 12 point (triple square)
    Dec 06 2007
    Calgary, AB, Canada
    Nope, it's only 12mm on aftermarket bolts. The stock OEM bolts are 10mm.
    Mar 21 2008
    Pass side axel is clicking hardcore
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    PS there's a really good tech article on AW regarding axle replacement. Has a list of tools and everything.
    Jan 11 2007
    Salt Lake City, Utah
    Yeah the stock bolts are 10mm. Add a big cheater bar to the list.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Dec 06 2007
    Calgary, AB, Canada
    If he follows the tech article he'll probably end up doing twice the work than is necessary. There is NO need to pull the control arms from the spindles or anything like that. Just use the floor jack to lift the spindle all the way up, turn the steering wheel all the way to lock in the opposite direction from the side you're working on, unbolt the axle, and work it out of the car.
    Jan 11 2007
    Troof
    LOOKING FOR:
