Results 1 to 27 of 27
    Registered User Three Rings S4M3's Avatar
    Jul 12 2007
    B5 S4,B8 S4, E55 AMG
    Atlanta, GA
    New RS4 Pipes ??
    I was looking around on ebay and i found new RS4 pipes. ?
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: New RS4 Pipes ??
    That's generationjdm from these boards thats selling them.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We've got genuine Audi pipes in stock now. No welds to worry about cracking, come with the factory flow straightener, and of course a perfect fit everytime.
    RS4 Inlets
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    BAH! perfect fit everytime!? haha sometimes even genuine audi parts need a little loving (sanding) to fit properly... or at all .
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    come on, these pipes will not crack ... they see no heat really. its not like they are exhaust manifolds. i say props to all the people who are making cheaper alternatives ...
    dont get jaded by rs4 this or that, it is just piping after all
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by DxC View Post
    My viewpoint exactly!
    Somewhere down the chain someone is making a KILLING off of these things. I mean 4 bent black pipes? I would be amazed if it cost more than 30 bucks to make these. Yet somehow by the time it gets to the consumer they are charging $550??! Ho please...
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Quote Originally Posted by alias747 View Post
    When there are no alternatives. . .Audi can charge whatever they want. That's the beauty of being the exclusive manufacturer of a high demand, mandatory part. Truthfully, who can blame them? That's what hustin' is all about. . .until now. jdm & 034 ftmfw.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by 2ndEngineS4 View Post
    +1
    audi has raped us for long enough
    Veteran Member Three Rings SourDieselS4's Avatar
    Feb 29 2008
    2001 S4
    New Hampshire
    hustlin makin that paper
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by SourDieselS4 View Post
    sorry i had to do it...
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Mike@PureMS View Post
    RS4 Inlets
    thats just funny.. there is no pressure.. no stress. and not much heat... you could jb weld these pipes together and never have them crack
    i just picked up a set of GEN JDM pipes and couldnt be happier..
    Awesome alternative to the RS4 ones.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Three Rings TalipseAWD's Avatar
    Apr 08 2007
    Stamford, CT
    goos to see these alternatives coming out.
    2000 S4
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    I came over JDM's house the other day and he had OEM and his side by side. He asked me to pick his set out and honestly I could'nt do it!?! They looked identical!!!
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    from what i have read the people using these pipes are extremely happy and I believe genjdm has warrantied these pipes if they ever did crack.
    B5 S4 AWE Stage 3 - sold
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    If this pipe ever by some miracle cracked I will frame it and stick it above my fire place.. I would replace it without a doubt, but it can never crack the weld is actually a lot stronger then the material next to it ie the pipe itself, plus the pipe has give in it as it's mounted by a coupler...
    Feb 17 2008
    Ottawa Ont.
    This is really beneath you guys. Shame on you. Just as bad as AWE attacking ER's intercoolers.
    Nov 23 2007
    Columbus, OH
    New pipes arrived yet?
    Jul 17 2004
    GenX Pipes > RS4.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Installing my ko4's as we speak. if i can get some pics i will of the piping. quick ? gen- where is the t-clamp you provide used ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    I'm not suggesting the welds are going to crack, but are you guys kidding me when you say the inlets are not exposed to much heat? They're right underneath the damn exhaust manifolds.
    B7 S4 Avant
    Jul 17 2004
    The inlet pipes aren't going through heat cycles and it's drawing in uncompressed air. It's not going to crack from indirect heat exposure... just look at the welded bracket on the pipe in your pic. That hasn't cracked.
    Alex
    Registered Member Two Rings
    Mar 21 2008
    va
    Because they make money selling rs4 pipes. And they lose money when someone buys your pipes.
    Jan 24 2006
    Ohio
    Quote Originally Posted by generationjdm View Post
    I'm completely shock on some of the stuff I here.. Hows this Josh I will take a blow torch and hold it right on the pipe I bet it doesn't crack ever, only 1 pipe has a 2 welds in it the rest are all 1 piece no welds and the pipe that has the welds in it sit much further from the manifold then the side you showed...
    Have you look at the crappy welds on the stock manifolds which could hit 1600 degrees, if that survived i wouldn't worry. The hottest the inlet on the outside will ever get might be 200 degrees.. Do you no how much heat it takes to burn a weld if you did you wouldn't of made this most ridiculous statement..
    By the way theres no welds on that pipe you posted there on the drivers side which has far more room and the welds are not even close to the manifold on that side. You have the thing wrapped which is making the pipe look much larger then it is...
    Josh, when someone else recently posted a set of new rs4 pipes that had 10 welds in them I don't recall you saying anything hmmmm..
    Ummm, are you kidding me dude? You MUST be illiterate. The first thing i said in my post was "I'm not suggesting the welds are going to crack." I was contradicting what someone had said about the inlet pipe's exposure to heat. I said nothing about your product.
    B7 S4 Avant
    Mar 14 2007
    michigan
    Sorry Josh for the mis post, it sounded like you where agreeing i must of misunderstood..
    Dec 11 2006
    Boston
    This is actually insulting to the average Audi guy, they must think where stupid...
    hahaha that is funny.
    Stage 3+ RS6's
    Jul 19 2007
    San Diego, CA
    Wow, amazing how you guys can twist my words.
    I have no experience with those pipes on eBay. I never suggested that there was anything wrong with these pipes in particular, I've never seen, handled or used them. What I have seen if people who can't weld try to put pipes together. Inevitably they crack due to poor welding or poor materials, or just poor fitment, causing stress in areas they shouldn't.
    Now, if you guys have experience with these pipes and they work, then more power to you. They're a great price, and if they work well, then great. I have no problems with competition, the more the merrier. I don't make a living selling RS4 inlets, so if there are other options it's no skin off my back.
    But when people link to products on eBay, with little info to back them up, it's natural reaction to approach those products with some hesitation. There's a LOT of junk on eBay. Since these guys aren't advertisers here or Audiworld, there's some obvious skepticism on the product. Don't take it personally, it's not meant to be.
    Good luck with them if they are indeed as good as people are saying.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Just for a heads up on Gen JDM inlets, I have them on my car, minor work has to be done to get em to fit, nothing you couldn't do your self. Also, he will help you out over the phone and help you in anyway. Good guy!
    l gotta-- l gotta get
    a form from a scientist.
