    Established Member Two Rings B61.8T's Avatar
    Sep 19 2006
    Silvia, B6 !.8T
    MD
    Transmission Actingin Funny
    So as I accelerate i can feel the car flucuate. Like It will accelerate, slow down then accelrate again like every couple hundred RPMs. I put it in tip mode and it still did it, so I know it is not the lag between gear search. Anyone got any ideas? Had My transmission serviced like 6 months ago, they rebuilt it.
    2002 B6 1.8T FWD
    19" August Werks with Perellis, VOTEX Body Kit
    Future Mods: HID Bi-Xenon, BT setup.
    Interior: Gauges, Carbon Fiber, AVIC D2, 10" SUB.
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Transmission Actingin Funny
    I'm having tranny problems too... the numbers on my dash keep disappearing and it's going out of "sport" mode on it's own. I've got an appointment at Audi tomorrow
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings natalia's Avatar
    Jul 13 2008
    hula hoops
    Denvemolorado
    If you are accelerating does it stop accelerating even when you still are trying to accelerate? This started happening to my car and it was the fuel pump. I ended up needing a tow, not sure if this helps but good luck
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I also think it could be fuel pump or something related to fuel (maybe filter). Try VAGing it and see if anything comes out.
    Sep 19 2006
    Silvia, B6 !.8T
    MD
    I had my fuel pump recently replaced, 3 months ago. Could it already start going bad?
    2002 B6 1.8T FWD
