It's located in the top rear edge of the engine. Close to the firewall slightly to the passenger side. It is plumbed into a black metal pipe (coolant distribution pipe) and has a circlip that holds it into a recessed socket. The harness is a 4-pin.
You should know that Audi recently (this past winter) mailed letters to V6 owners regarding the ECT sensor and it being covered by Audi should it fail or throw codes.
I recommed that you call AoA and check to see if you are covered because your P0118 code is directly related to the ECT sensor.
Originally Posted by
Audi Website
If you currently own an Audi and have questions or concerns about your ownership experience, and would like to speak with a Customer CARE Advocate call 1-800-822-2834 (AUDI), Mon-Fri, 8 am to 8 pm, Eastern Time.
