I finally put a boost gauge in... I expected the 20psi steady, but not the 25-30psi spikes I'm seeing... I also don't have the manual boost controller on.. is this normal? it runs mostly fine, but I seem to get spark blowout in 5th gear fully loaded (kind of a soft hesitation, but no pulled timing or anything, not temp dependant).. I've got the usual stuff from eurocode: evolution race works comp FMIC, Neuspeed TIP, Forge, ATP mani, APR exhaust, test pipe, 3.0 inlet snorkel, .025 plug gapped Denso iridiums (everything else missfires), SAI delete.
TIA
