Results 1 to 40 of 43
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    Received my coilovers
    Hi all,
    Today I received my statis ss coilovers from performance cafe. I don't see any Stasis markings on the box or coilovers. My understanding is Stasis are using Koni equipment, but i figured their would be some markings. I'm going to put up some pictures if anyone can enlighten me. Either way, ill be installing them tomorrow.
    Also, i didn't recieve any papers in the box. Stasis website says:
    A. Adjust damper settings and ride height PREVIOUS to installing your kit. Refer to the adjustment
    sheet included in your package.
    Does anyone have a copy of this? I would like the car to be a bit lower than the Stasis preset, if in fact these are Stasis.
    Any help would be greatly appreciated. Advice for tomorrow also welcome.
    May 20 2004
    More cars
    Never Land Ranch
    Re: Received my coilovers
    Stasis FTW!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i ordered koni coilovers from perfcafe and received the same package. i ordered mine about 2 weeks ago, and they told me no stasis available til at least august.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    Quote Originally Posted by SEXICAN View Post
    Stasis FTW!
    where you at over on my thread? haha... http://www.audizine.com/forum/showthread.php?t=225221
    what ride height are you at? that looks like a perfect drop. great looking ride.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    http://www.stasisengineering.com/faq.aspx
    Quote Originally Posted by STaSIS Engineering
    Conservative Street Setup
    Between 1/16 and 1/32 TOE IN front and 1/32 TOE IN rear
    Ride height at 25.875” front and 26.000” rear
    (–1.0 camber front)
    Aggressive Street Setup
    Between 1/32 and 0 TOE IN on all four corners
    Ride height at 25.500” front and 25.625” rear
    (–1.5 to –1.75 camber front)
    Track Setup
    Between 0 and 1/16 TOE OUT on all four corners
    Ride height at 25.000” front and 25.250” rear
    (–2.0 to –3.0 camber front)
    WARNING! The Track Setup alignment recommendations are not for the street and will result in serious straight line instability. STaSIS accepts no responsibility with its alignment suggestions.
    2006 Audi A4 2.0T Quattro 6MT S-line
    May 20 2004
    More cars
    Never Land Ranch
    Not sure of the height, I had my dealership do it. Out the box from Achtuning and they went a bit lower from that. I then when to my dealership(where i work) and went lower! I also went from 18's to 19's so i have since adjusted them...
    I wish I knew....sorry!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Jun 04 2008
    RSF san diego
    integration: thank you!
    So the conclusion is that i ordered stasis and received konis instead. What height are konis preset at? lower/higher than stasis?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Konis are not preset, that is the main difference between buying from Stasis and buying a Koni setup. Hardware is exactly the same except Stasis comes with a spacer for the rear and Stasis presets ride height and rebound for you. I have mine set to 2.5" from the top of the thread in the front and about 5 threads in the rear. You don't have to lower the back much at all because Koni's set you below sport height even at the max height they can go.
    Click on my sig to see a pic of how my car sits.
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by akaEsCo01 View Post
    Your cars stance is perfect. Can you help me with setting the dampening?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by sdjeff View Post
    These are KONI coilovers, not Stasis Street Sports. Sounds like a mistake.
    Jun 04 2008
    RSF san diego
    I started the install today. I only got one corner done but didn't start until pretty late in the day. Overall a fairly easy and straight forward job.
    I adjusted the dampening all the way to the right and than a half turn back on all 4. I want them stiff.
    I adjusted the height for the fronts at 2.5 inches from the top of the threads like akaEsCo01 suggested. I lowered the car off the lift to check ride height. There is about a half an inch gap between the fender and tire. I never rolled it back off the lift, only straight down, so i am guessing it will end up dropping a little more once backed off and driven. If it will drop a bit than i will be happy with the ride height. Can anyone chime in if it will?
    Tomorrow hopefully ill finish them and post some pictures.
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    post pics when done!!!
    BTW why the mistake and why didnt you send them back for the stasis?
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Jun 04 2008
    RSF san diego
    Stasis were out of stock for a few weeks. I didn't want to make a big fuss out of since they are so similar. Ill be looking forward to putting up pics because it means ill be driving it
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    very exciting man! i'm getting mine installed friday. so any other info on your setup would be great. i think i may go for a slightly softer ride than you, but sounds like about the same height target. can't wait to see pics.
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    Pics Pics Pics
    Jun 04 2008
    RSF san diego
    Finished the install. The rest went really quick. I took it for a test drive and am hearing a clanking sound on the back rear. It also seems like the fronts are making a slight springing noise. Anyways im gonna put it back on the lift and check things out, make sure all is tight and try and troubleshoot. Any suggestions welcome.
    Registered Member Two Rings Teddy M's Avatar
    Jun 25 2008
    2008 Audi B7 a4
    Miami, Florida
    wow looks great? how much was it all, installed?
    Black A4 b7 S-line
    -15% tints
    -Test pipe//downpipes
    -debaged
    -blacked out tail lights
    -exhaust with quad tips
    -S4 valence
    - hula dancer on the dashboard
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Those are definitely a standard Koni kit, did Performance Cafe tell you that you were buying a STaSIS SS kit?
    Jun 04 2008
    RSF san diego
    looked around and found 2 nuts a little loose. the rear is fine now. the fronts both make a click noise when the suspension is compressed quit a bit (when both me and my dad push down on the car hard a few times).
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by Jared@STaSIS View Post
    That is what i ordered. I talked to performance cafe and they said they sent out the standard koni kit because the stasis were back ordered. I could have chosen to send them back and wait but i felt confident that i could set them up correctly. Obviously im having a few problems pictures will come in an hour or 2.
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by Teddy M View Post
    995$ plus tax which ended up almost $1100 i think, and than i did the installation.
    Jun 04 2008
    RSF san diego
    i must have been drunk when i put together the front coilovers.. springs are upside down! such a stupid mistake. Anyways, taking everything off now hopefully will have it fixed in an hour or 2
    Jun 04 2008
    RSF san diego
    fixed.. everything is perfect now. I was really debating coilovers and thought i would regret them but i dont have any doubts now. The ride is unbelievable. I have my settings at 2.5 inches from the top of the threads for the fronts and for the backs i screwed the perch all the way down and than 4 turns back. It ended up exactly how i wanted it. Heres a crappy picture i just took, better ones to come.
    Jul 14 2008
    Nissan X-Earth
    Orem Utah
    Very tight! Very Sexual! Looks great.
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    ^^whoa. down boy.
    i think it looks good, def need some more pics. my koni's are gettin installed at this very moment. can't wait to see how they come out.
    Jun 04 2008
    RSF san diego
    Here are some new pictures. I drove up to laguna today to pick up my cupra lip from oempl.us but i didn't install it yet. Great guys up there. Eventually ill be adding some BBS LM's unless i get swayed in another direction.
    Good luck with your car toothy!
    May 21 2008
    Looks perfect!
    Nice Job
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    wow that drop is perfect. nice work
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Jan 06 2008
    Dacia Sandero
    Arizona
    Wow, nice work! Especially for your first time!
    The drop looks perfect.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    rough first day. ha. the guy who did the install had trouble adjusting the height with the coils on the car so it ended up being a little too low. they are on though. i've got to go back in a week or so to get them raised some. i'll be bringing your settings along to give him some reference.
    great pics!
    Jun 04 2008
    RSF san diego
    thanks for the comments guys
    Quote Originally Posted by toothysaw2 View Post
    great pics!
    pics are needed!
    Registered User Four Rings PerfCafe's Avatar
    Nov 27 2007
    is where we work on cars!
    Monterey CA
    Car looks beautiful man!
    We most certainly very specifically said you would be getting Koni's instead of the Street Sports due to the back order so you wouldn't have to wait! Anyways glad you are happy with your setup man looks sicky!
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    looks great bro love it !
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    May 29 2008
    TRINIDAD WEST INDIES
    sdjeff did you get the tool to do the adjustments ? that little white thing you see on the box on top of the shock next to where it says lowers up to 60mm ? as i just received the same setup and the contents of the box are the same let me know
    tks
    scot
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Dude your driveway is sick! And i guess the car too
    Nov 27 2007
    Monterey CA
    Quote Originally Posted by a4sdaride View Post
    tks
    scot
    each kit should come with one key!
    May 29 2008
    sdjeff did you get the adjusment key with ur kit ?
    May 29 2008
    percafe i did not receive the key ...is there anything else that can be used ?
    let me know
    tks
    Nov 27 2007
    Monterey CA
    let me know
    tks
    thats not right lets get you a key! PM'ing you!
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    I'm gonna try to sway you. Your car looks unreal with the S-line 5-spokers. I would keep them and spend my money on other things.
