Results 1 to 22 of 22
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Ready....set....fight....
    Just got my meth injection and modified RS6 turbos from vast. Its gonna be fast!!!!
    By elijahallen, shot with u770SW,S770SW at 2008-07-21
    Elijah
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    Re: Ready....set....fight....
    nice, i want water/meth .. post numbers when you get it all done.
    -Luis
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    mmmm.... exact same setup i'm looking into
    J Fonz Stage II+
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    Wow, can I has both or your cars??? Jk man, its gonna be sweet after the install
    Active Member Four Rings
    Jul 17 2004
    Great turbos, great meth kit.
    Did you go with #3 nozzles?
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    how much did you invest in that?
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    love it!
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Looks great. Are you doing the install or are you taking it to a shop?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 12 2006
    Michigan
    Thanks for the good replies, I thought this would be a fight over why I didn't go with such and such and so and so, haha. I will be installing the meth kit myself and the turbo's with pauder rods with a friend in his shop. Should be fun but not out of control
    Jun 14 2007
    2000 S4
    Connecticut
    awesome! i rock the same ECU... love the logo hahaha. If I ever do anything else do the car it would probably be RS6 turbos down the road and build up the engine a bit for whatever its worth. wish you luck!..... do you have a wideband for real good tuning with the turbos ?
    Nov 12 2006
    Michigan
    No wideband, I'm not going for huge power, just want a more efficient setup for track. The brids just make too much heat at the power level the RS6's should be able to handle with less boost.
    Elijah
    Jun 14 2007
    2000 S4
    Connecticut
    cool. this is OT a bit but i notice you have Hsport sway bars. I have H&R coilovers and love the suspension but turns SUCK. like my car dives into every turn no matter how small. im on stock front and rear. how are the hsports you like them? im going to do the front and rear just want your opinion since you have them :)
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    cool setup, wish i had all that baller stuff.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    logo is for Subarus, why does Vast rock it for a logo on Audis?
    ...and OP, i hate you haha. where do you live,im stealing both your cars and your new setup!
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Nov 12 2006
    Michigan
    The H-sports are a great addition. It made the car alot more neutral on the track. The rear is a little too stiff on the stiff setting with R compounds at the track but I leave it on stiff for the street and switch it to the softer setting for track.
    Jun 14 2007
    2000 S4
    Connecticut
    interesting thank you for the reply. its so disappointing how much straight line speed the car has, then through a turn i can LITERALLY take my moms beetle, not even turbo LOL through a turn faster! 8 year old sway bars FTL
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    how much was the w/m kit?
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Nov 12 2006
    Michigan
    Quote Originally Posted by casawhites4 View Post
    $350ish
    Veteran Member Four Rings raketeS4's Avatar
    Feb 14 2006
    2000 B5 S4 Stg II+, 1977 BMW R100/7
    Quote Originally Posted by EuroSteez View Post
    what?
    2000 B5 S4 Stg II+
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by raketeS4 View Post
    what?
    i think what he means is that pig picture is also a similar logo to a subaru company as well. Ive seen it on an STI before i was like NO IMMMMMMMM piggie tuned fucka! lo l
    Feb 14 2006
    god damn subie posers
    2000 B5 S4 Stg II+
