Results 1 to 14 of 14
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    Questions about TT Install: UPDATE: INSTALLED!!!!!
    I have the TT wheel on and all i need to do is plug in the airbag, i have the harness for the TT wheel but it is different then the harness on my regular a4 steering wheel, do i just rewire the TT harness using the original plug, the TT plug will not fit into the SC Ring. The wheel looks so amazing, and i want this to work. I didn't buy a new SC Ring or module because i'm not using the multifunction. Please help me!!!
    thanks in advance.
    USP CLUB MEMBER #94
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Re: URGENT!!! HELP!!! Questions About TT WHeel Install
    I thought I answered your PM on this one. Look at the two plugs. Are they the same config? I found that the TT plug was only slightly different in that there are tabs on the side that are different between the two. I trimmed off the side tab that didn't align with the S/C plug socket. You do not need to reconfugure the airbag wiring and you're not using multifunction.
    Important - make sure to disconnect battery whenever working on airbag.
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    thanks man i will look at it again, it doesn't even look close though, let me go look again, hopefully your a life saver!!!!!
    ohh by the way, i have the battery unplug, i'm safe there
    USP CLUB MEMBER #94
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    Update:
    Installed!!! Looks Amazing!!!
    USP CLUB MEMBER #94
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    Re: Questions about TT Install: UPDATE: INSTALLED!!!!!
    USP CLUB MEMBER #94
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    you have the wheel but you don't have RNS-E?
    it looks so poor with the Symphony II there.
    anyway nice steering wheel
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    i'm going to be installing the avic-d3.
    USP CLUB MEMBER #94
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Looks cool. 2 questions:
    1) does the horn work?
    2) is it not the same color as your interior?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Aug 11 2005
    NW Suburban Chicago
    Glad you were able to get this to work! The wheel is amazing, isn't it? Did you trim the plug as I suggested?
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    so this might be a stupid question but if u have a manual trans can u use the multifunction since i didnt have it before like can i wire it some how?
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Aug 11 2005
    NW Suburban Chicago
    Quote Originally Posted by whiteUSPflow View Post
    Multifunction only pertains to Radio/RNS-E/Nav/Bluetooth functions. You need to upgrade your S/C ring, control module and vag-com to get it to work. Look at the write-up by HX_Guy. Multifunction wheels are also made with paddle shifters for tiptronic cars.
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    i trimmed the hell out of the clip like you said and the clip can be installed in either position and i think i installed it upside down because my horn doesn't work and my air bag light is on, so tomororw i'm going to take it apart and flip the plug around and see if that fixes it. We'll see, otherwise i will just go buy VAG-Com and reset my airbag light. I will also take pictures of the install for future people. oh and by the way the wheel is absolutely amazing and it matches the interior or it's very similar were you don't notice.
    USP CLUB MEMBER #94
    Nov 09 2007
    Australia
    Quote Originally Posted by zbrock06 View Post
    Would be brilliant if you could
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    wow! thats all im going to say.... WOW!
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
