Results 1 to 17 of 17
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    What kind of oil do you guys use?
    I'm up for my 5k mile service and I called my service manager and asked what kind of oil do they use and he said they use castrol 5w-40. I told him I used mobil 1 0w-40 for my other cars (04 gti 1.8t) and he said that's too thin. Living in Socal, what do you guys use?
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Re: What kind of oil do you guys use?
    0W-40 Mobil 1
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    0w-40 mobil1 only the best
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    i've never had any experience with castrol and i'm kinda not digging it.
    i always use 0w40 with all my cars and never had a problem.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    I'm going in for my 5k on wednesday, I'm interested to see what they say.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Your service adviser is right about NOT using 0w40. Especially on "hot" summer days where the oil might be too thin (in terms of viscosity) provide enough lubrication to protect your engine internals.
    Sure you might yield a few marginally more hp (think like 1-3) by using a thinner oil, but that subtracts from the life of the engine...unless of course you leased the car and plan on retuning it later on before the long-term damage begins to kick in.......................... I'm not taking sides, just informing you of all the potential effects
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    I've heard and seen a european/german blend of Castrol Syntec that is good for our cars.
    Do any of you guys use that?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    AWD_4TW
    ^ How about screw Castrol, Mobil, Pennzoil, etc.
    Motul, Redline = FTW, on the other hand I've been seeing pretty good reports with people using Torco recently also. Some guy recently filled up his Evo X with Torco and it yielded higher tq/hp numbers on an AWD dyno.
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by INTEGRATION View Post
    Forgive my ignorance on this topic, but are Motul, Redline certified to be used in our motors? I forgot the numbers that designate if they are or not, but our manuals say which spec numbers to look for on the bottle of oil if they are ok to use on our motor? If a brand of oil doesn't have those numbers is it still ok as long as it has the proper weight.
    Although I haven't hit the 5K mark on my car, I'd like to know too which oil I should use when the time comes. I'm currently at a little over 1K on mine.
    -Anil
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Audi has a PDF file of VAG approved brands and their viscosity. I cant find the link unfortunately.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    AWD_4TW
    http://www.audiusa.com/etc/medialib/....0023.File.pdf
    ^ That is the official list, but the stuff I'm thinking of isn't listed on there and definitely out-performs those oils in terms of performance enhancments AND protection.
    Jan 22 2007
    Fontana, CA
    Thanks for the link!
    Question about oil weight. Looking at the list, some of the oils listed are 5w-30, some are 5w-40. Which weight is better based on what conditions you live/drive in? I'm a newbie when it comes to knowledge about oil, so be gentle on me if I ask stupid questions.
    More generally, what do the different oil weights mean?
    -Anil
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    i run motul 300v 5w-40 here in hot and humid south fla... love the oil. highly highly reccomend it
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    AWD_4TW
    Well your location is a bit on the "hot" side for Socal (I grew up in Diamond Bar actually so I remember how it gets there). As for a recommended weight/viscosity: there are a lot of other factors that can be taken into consideration and I can't read your mind and so I would not be able to give you "good" suggestion based on your wants.
    But you may want to read this, it should provide some helpful insight as to what you think is the best for yourself.
    http://auto.howstuffworks.com/question164.htm
    Quote Originally Posted by Ih8OEM View Post
    YES! YES YES YES!
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    Elf oil.
    Jan 22 2007
    Fontana, CA
    Thanks, i'll read up on that and try to find some other info and come back with hopefully something to contribute.
    -Anil
    Deactivated Three Rings
    Dec 30 2004
    Palo Alto
    We use Pentosin 5w-40 on all 2.0t's with never an issue at all.
