Results 1 to 8 of 8
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Turbo making weird noise?
    When I boost from about 5-11 pounds...I hear a sound that sounds almost like when you slowly let the air out of a balloon. any ideas?
    Sep 24 2007
    Woodbridge, Ontario
    Re: Turbo making weird noise?
    Hmmm?
    Sep 24 2007
    Woodbridge, Ontario
    Bumpzilla
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    is it hissing, be more descriptive, could be a boost leak, defective DV, did you change anything lately, is it stock...etc..
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    similiar sound was bent fins on the turbo... after installing afe intake and a gromet broke and went through the spin cycle.
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Bent fins will sound like a jet engine or dentist drill. What DV are you using? Diaphrams DV's like the 710N go out whenever they feel like. I had a new one go in 2 weeks when I had a K04. Might want to pressure test the system.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Might want to take a look at the PCV valve and hoses, .......similar symtoms to yours.
    Good luck
    http://www.audizine.com/forum/showthread.php?t=164078
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Sep 24 2007
    Woodbridge, Ontario
    Im using a generic billet aluminum diverter and ive had it on for about 8 months.
    Im still holding around 20 pounds of boost its just that certain boost range where the noise happens.
