    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    Anyone else's fans sound like a plane?
    Just wanted to know if its normal for my fans to be soo damn loud....
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: Anyone else's fans sound like a plane?
    Yes , on super hot days, the hyper fan on the front of the radiator kicks on.
    Try hitting the "econ" button on you A/C to see if that turns it off.
    There are cases of the regular fan breaking apart and not functioning, so take a took in there to make sure everything is moving the way it should.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    OK i'll check it out. Thanks
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1996 VW jetta VR6
    AMS AUTOWERKS #1
    Feb 05 2008
    Overland Park, KS
    Yes, and it keep going a few secs after you turn the engine off. Neato indeed.
    Established Member Two Rings Snowhere's Avatar
    Mar 20 2008
    2001 A6Q Avant, 90 G60 Corrado
    Buena Vista Colorado
    Yes, mine sounds like a plane too. Not quite as much looks as the charger on my Corrado, but looks never the less.
