Long story short i had to replace my trans pan cause i scraped and put a hole in it. so after replacing the pan,filter, and gasket it was still leaking, but from the gasket(used permatex on the gasket) go to dealership to buy a new gasket and ask the tech if the gaskets need to be permatexed, he said no. so i put the new one on sans permatex and its leaking worse than it was. so here i am losing $15/quart fluid with no real solutions. i was thinking maybe an extra lock washer to pull the pan tighter (maybe the old torx aren't pulling it tight enough (especially after the wrestling match i had with them)
but thinking about it logically, it seems that something is causing alot of extra pressure inside the transmission pan and forcing the fluid through the gasket.
any ideas/suggestions?
