Results 1 to 13 of 13
    Active Member One Ring A4now's Avatar
    Jan 03 2007
    OH
    Oil Change DIY? A4 B5
    I have a 98 a4/2.8/Quattro. I've never changed the oil on this car myself but have on previous cars. Is the drain plug on the rear or front of the case? I plan on lifting the front end, on ramps or stands vs using a lift to raise the entire car, and was wondering if the oil will drain properly by lifting only the front end.
    If lifting the front end only vs the entire car is adequate, then do you recommend ramps or jack stands to get plenty of clearance to work underneath.
    If there are any other recommendations or sugestions regarding the process that I might not expect please feel free to comment.
    A4Now
    '03 A4 QUATTRO 3.0
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: Oil Change DIY? A4 B5
    Ramps are enough for me. I can't say where the 2.8 drain plug is but I can't imagine it'd be very hard to find... just look at the oil pan.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    You don't even need to lift the car. My car is lowered and I don't lift it at all when changing the oil. The plug is on the drivers side right near the front. The filter is right around their as well. Very easy car to do an oil change on. Also the engine does take slightly more oil than the book says, So just fill it up till the dipstick says it's good.
    May 19 2007
    Bay Area
    Must not be very low
    I can't even fit my whole fist underneath my car unless its up on something.
    SIXFIVEOHphoto
    May 12 2007
    MN
    Probly not compared to yours, Bilsteins with Eibach springs. Low as I wanted to go with the MN winters.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Pretty much what 777 says. Mine is not lowered....yet....anyway, I have no trouble getting to the plug & filter. Lotsa room unda there.
    Do get the right sized mm socket and make sure your filter gasket comes off with the filter.
    May 16 2008
    WA
    Quote Originally Posted by MattzWarsteiner View Post
    had that happen to me once when i forgot to double check on a car i had along time ago, it was a smoke show lol
    Jan 03 2007
    OH
    What about the filter? Any issues with using something common like Fram or STP? It's my understanding that Audi Filters have some sort of valve to keep oil in the filter when the engine is shut off...per the parts/service guy at the local dealership.
    A4Now
    '03 A4 QUATTRO 3.0
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    2.8 oil change is SOO easy to do. Filter is right on the bottom. Just drive up on ramps, take off the plastic cover, drain it, change the filter, pour in new oil. The car takes like 5+ quarts.
    Buy OEM Filter Here
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    May 22 2008
    is full of crap
    sandville
    OP, heres 2 links I got from this thread.....Oil Filter Revealed & Oil Filters Revealed.
    I learned a bit from that thread & links, like the reason we need the anti-drain valve is the filter orientation > Horiz vs Vert.
    Quote Originally Posted by getslideways View Post
    YikEs!. Could have happened to me too. lOl. Now I always line up the old filter gasket with the new, to check for size and it also oils the new one. 1st time I did this car, there was no gasket to match and it was stuck above.
    Senior Member Two Rings rdguy's Avatar
    Oct 12 2006
    14%20Audi%20A4%20Quattro%20%26%2087%20M
    Mississauga
    My 98 has a plastic belly pan that needs to be removed before you can get at the oil pan. 3 screws in front, 3 in back and 1 or 2 at each fender well. I suggest using a 6 point socket to get the drain plug off. A 12 point socket or wrench may slip and strip the nut. (ask me how I know, it just happened last week to me) Luckily new drain plugs are available at the dealer.
    Jan 03 2007
    OH
    done. thread over. thanks for the info.
    A4Now
    '03 A4 QUATTRO 3.0
    Established Member Two Rings isramirez21's Avatar
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    __________________.
    +1
