Originally Posted by
festerfm
i kno the dif between diodes and resistors but i've never put resistors in a circuit like that.. didnt kno if it made a difference if they were put before or after light. and it's not city lights. i dont have them in my car. just reg turn signals. is that something where i just need to get my meter out and check the resistance for the reg bulb and add the proper size resistor... and that means 1 resistor for each bulb too right?
A 220 Ohm, 1 WATT (Power Dissipation Rating) resistor is recommended to prevent the lamp failure warning regardless of the application. The bulb check system uses the same method of checking all of the stock incandescent lamps, so the same resistor value that works for the City Lights, will also be suitable for LED tails, or any other lighting monitored by the bulb check system. The resistor is connected in Parallel with the LED, not in Series, (in-line before OR after the LED,)
See:
http://www.glenbrook.k12.il.us/gbssc...its/u9l4d.html
