So I've been doing some reading on using relays and I stumbled across two products that may make this work.
DEI 528T Pulse Timer $8-$13 each
# Pulse timer with SPDT (Single Pole Double Throw) Relay
# Adjustable Timer Control From 1 to 90 seconds
or
DEI 611T Programmable Switch = $13-$16 each
# Programmable solid state switch
# Program to: Normally Open, Normally Closed, Timed Toggled or Timed Latched
# 1 - 100 Seconds variable program
# Negative or positive pulse activation
I need the wiring diagram for the power folding mirrors though. So if anyone has it I'd appreciate it!
On a side note..I'll also be using the DEI 611T to convert my "FUNK" switch from a momentary pulse to a bi-stable (On/Off) switch. I needed to do this so I could turn on the
640 Servotronic relay back on when parking.
