    Oct 05 2004
    NH
    01 A4 2.8 clutch engage/disengement height adjustment
    Any way of changing when it lets out. Mine lets out wayyyy at the top. It's at the point of being awful.
    Thanks
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    Re: 01 A4 2.8 clutch engage/disengement height adjustment
    when I bought mine it let out wayyy at the top of the pedal travel. From the sounds of it yours is the same way. That means you most likely need a new clutch. I did. Even with the new clutch is still lets out high but it's much better than it used to be. Unfortunately the clutch is hydraulic so you can't adjust it.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    +1 No adjustment on our clutches
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Quote Originally Posted by xraycer2012 View Post
    I think you meant to say, "Fortunately, the clutch is hydraulic, but as a result cannot be adjusted."
    I learned to drive stick on my brother's Saab with mechanical clutch and it felt like a Stage 4 setup.
    I've actually grown to like our clutches... I much prefer the Audi/VW clutches to BMW clutches.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    its normal, you have to get used to it "up"
    2004 Subaru Impreza WRX
    Aspen White
