Results 1 to 40 of 58
    Apr 14 2008
    a4 avant
    marlboro
    finally got it on the dyno....
    finally got it on the dyno, unfortunately i couldnt get 30 lbs so the the first run was at 22 and the rest were between 22 and 26, the one line that stops was somewhere around psi on my gauge could be 35-40lbs do not know...however the graph did seem pretty nice
    here you go mind you this was on a 100 plus day:
    -vrt-
    Sep 17 2006
    07 cbr600
    Re: finally got it on the dyno....
    thats sweet man, i think i saw your avant at waterfest today, it was good to see you repping the avants and the BAT at the same time. Def should have been more of them showing.
    Apr 14 2008
    a4 avant
    marlboro
    thanks man...it was fun i just wish i could haved gotten to see what 30 was like!
    -vrt-
    Feb 27 2005
    North Wales, PA
    thats sick man. good numbers.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Wow....great numbers....Where are you located?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Feb 27 2005
    North Wales, PA
    I was also there when the judges were looking at your car. They were wondering where the hell you were. I should have pretended to be you so you car could get judged. Oh well. hows the tapp tune treating you?
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    were you parked @ the Ramada in East bruns Friday?
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Oct 29 2005
    10speed
    San Francisco, CA
    Hey man looks good. I was the one asking you a few questions when you were on the dyno... I got my 50 trim going in soon...
    So was that on pump gas? and this
    "the one line that stops was somewhere around psi on my gauge could be 35-40lbs do not know"
    what does that mean? 35-40lbs of what? I thought you said the boost was between 22-26psi
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    no not at the ramada...the tune is lovely i think i could have brought it to 30 with out problems and on a nice cold day with good cooling i could hit over 4....im setting up a another dyno soon should be better...
    -vrt-
    Feb 27 2005
    North Wales, PA
    were you running race gas? I'm surprised you bumped up the boost that high on stock compression. At that point you are probably sacrificing a lot of timing to keep the motor happy.
    Another note, its a bit strange that the HP and Torque don't seem to intersect at all even after you correctly scale the graphs. They usually cross at 5250 rpm.
    Apr 14 2008
    a4 avant
    marlboro
    i was on 116 sunoco race gas....i will drive it at 25lbs on pump all day long...the one run that the guy let off is not on the plot and that run the boost skyrocketed to where it says psi in my guage...
    -vrt-
    Registered Member Two Rings kextyn's Avatar
    Sep 15 2005
    2001 A4 1.8TQM
    Virginia Beach
    35-40lbs per square inch
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by kextyn View Post
    I see, I just didnt understand how he went from 22 to 26.... I thought he was on pump but he wasnt so it makes sense
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    what i meant by between those two is that one run i ran like 22 and kept bumping it up till i hit 26
    -vrt-
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    wow...so my "little" 50 trim had some definite potential! awesome numbers! I would have liked to see some numbers on good ole 93 pump too though.
    The harder I practice, the luckier I get.
    - Gary Player
    Apr 14 2008
    a4 avant
    marlboro
    that dyno will probably be coming up in a week or two in a shop with real fans and a much colder day
    -vrt-
    Quote Originally Posted by Poopie View Post
    what he said.
    contact via email please.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I felt that power shake me from inside out man. Good results!
    I got some pictures and have a picture of the 377 whp run if you want it.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    This is something I never understood.
    I watched your car get dyno'ed. Pretty damn decent numbers. I tried videotaping one of your runs, but I ran out of room on the memory card.
    Bumping it up from 22 to 26psi made the world of a difference from the spectator's point of view. That thing sounded f-in amazing on 26psi.
    Feb 27 2005
    North Wales, PA
    because dynos measure torque...and horsepower is a function of torque. Horsepower is calculated off torque....so if you have a torque curve, you also have a horsepower curve.
    Horspower = (Torque(ft lbs) X RPM) / 5250
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    My plots from Sunday don't cross up at 5250 at all or anywhere near for that matter. That dyno was 1) beyond off and 2) the heat and humidity were brutal.
    ^ what did you put down?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I've seen the calculation before, I just never messed with it to see why. I get it now.
    (300ft lbs @ 5250rpm)/5250 = 300HP
    The 5250's cancel and the numbers match.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yup thats why the numbers are supposed to cross at 5250. buut say you make 300tq at 7000 rpm, then technically you should make 400hp at 7000rpm. (300x7000)/5250=400hp
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 27 2005
    North Wales, PA
    you will always make more hp then torque after 5250 rpm.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    It doesn't cross at 5250 because the hp and tq scales are not equal. The hp is scaled for a max 400 reading and the tq is scaled for a max 350 reading. If they were both scaled for 400 the 2 lines would cross at 5250.
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    nicely done
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    good numbers.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Apr 14 2008
    a4 avant
    marlboro
    so mike what do ya say wanna reclassify my lil avant now...?
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    What do you have for internals? Are you still 1.8, or upped it to 1.9-2.0?
    Apr 14 2008
    a4 avant
    marlboro
    1.8 still only rods....however i believe my head is about to go sooo maybe cams and some other more safe yet high rev goodies might be going on...
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Nice.
    I was just doing the math and tinkering around,... in order to make as much power as you did, you would have to make 200% volumetric efficiency. Or more.
    At 26 psi that turbo is working pretty damn hard. I looked and sounded great though.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Nice numbers!!! what race gas file do you have 104oct or c116file???
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Apr 14 2008
    a4 avant
    marlboro
    104 but when i put them down it was about 5galons of 93 and 8 and a half of 116 so pretty much what ever that breaks down too
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    the best part was there was way more to go the curve only seemd to be better when the boost got higher...i cant wait to hit another dyno at 30psi or more
    -vrt-
    Feb 27 2005
    North Wales, PA
    works out to be about 106oct
    May 31 2005
    Dallas
    how was your afr
    May 31 2005
    Dallas
    what about 5gal of 116oct. with 7.5gal of 93oct???
    Apr 14 2008
    a4 avant
    marlboro
    no clue on those pulls but generally between 11.1-11.5 on pump at 25lbs so i assume roughly the same. i never got to sit in the car during the pulls
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    the only thing worring me was i loged it yesturday at 20lbs on the mix or whats left of it and im pulling timing upwards of 38 degrees on a hard 3rd gear pull
    -vrt-
