Results 1 to 3 of 3
    Veteran Member Three Rings sfored's Avatar
    Dec 30 2004
    Transmission Question
    Car is running on on Jackstands about 20 mph-
    The tranny is just put into the car - was never in before.. it is a 6 speed with a center diff. Clutch is CM - twin disk.
    First, second, third goes into gear fine and smooth driving (up in the air).
    Reverse, 4th, 5th and 6th go into gear but grinding noises and kinda rides the stick - wanting to kick it out but doesn't ..
    I believe it is aligned properly, because it find all the gears.
    Any ideas ?
    Linkage ? Tranny ? Diffs ?
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Transmission Question
    Quote Originally Posted by sfored View Post
    Any ideas ?
    Maybe you just have to drive it, you need to put load on the motor when sealing the rings btw
    - Clint
    Dec 30 2004
    I hope you are right....
    I will know tuesday ...we are making a break-in map... :))
