Results 1 to 11 of 11
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    What revo setting do u run?
    What setting are you guys running with your revo software?
    B7 A4.... 394awhp
    DUH! an Audi
    los angeles, CA
    Re: What revo setting do u run?
    6-2-9!
    is what you should be using
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    6-2-9 stage 2 > randy
    DUH! an Audi
    los angeles, CA
    Randy > Will's Stage 2
    Senior Member Two Rings NKI 337's Avatar
    Apr 24 2007
    Miami, Florida
    6-2-9????????
    I have spoken several times to reps of REVO and i have been told 7-4-9 or 7-4-8 here in Miami, Florida...
    Please, somebody verify, these setting are very far off from each other.
    ***** www.dubbersinc.com *****
    Jun 26 2008
    New Jersey
    I just find is strange because on the SPS guide it states if you are running 91 octane gas use time 1-3 and if you are using 93 to use between 4-6. Just a bit confused if i should have a different timing number because of the fuel I'm putting in. My default is 6-2-9 but my installer put in 6-3-7.
    B7 A4.... 394awhp
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by NKI 337 View Post
    6-2-9????????
    That is fine, you know that logs don't lie and timing 4 is perfect even on 90 degree plus heat.
    I ran timing 8 with meth the first summer I got it and the logs always said no timing pull, so as they do when is off and I run 4.
    Now fueling it tends to depend on the car.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    DUH! an Audi
    los angeles, CA
    for fl are you running 93 octane? i think programing MIGHT be different based on octane or mods like HID
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Quattro View Post
    For a car that only has the essentials for stage II Boost 7 Fuel 8-9 and timing 4 ( On 93 ) should work really well.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    i'm running on 91 octane, stage 1 Revo - no other performance mods outside of the chip - AWE exhaust coming soon
    what settings should i run for optimal performance?
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    although it does not spell it out, there is an advanced user guide for the revo switch online in pdf form. from reading it and talking with the shop guys, here are some common settings
    6-2-9 (factory tune, optimized for 91 octane)
    7-3(or 4)-9 (aggressive tune, optimized for 93 octane)
    8-5-9 (Stage II but some get fuel cuts and some say its too aggressive)
    any higher boost (9) is probably only for a bigger turbo and any higher timing is probably only for race gas or water/meth
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
