Results 1 to 30 of 30
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    VAST EFK Wiring issues
    If you have installed a VAST EFK on a car before, did you get a relay with 5 connection points? I seem to have places for 4 connections as well as a diagram of 4 but there are 5. any help would be great especially if it were a picture you took of your wiring. Thanks.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    Re: VAST EFK Wiring issues
    i used 4 wires i didnt use the blue wire i think might have been the 87a u dont use not sure. I had a problem finding a signal wire i got pissed off and hooked it up to my foglight switch
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Dec 10 2006
    Wisconsin
    http://www.audizine.com/forum/showth...ght=vast+relay
    This post by JHM contradicts VAST's instructions. Jason says to use #86 to pos battery but that's where #30 goes. These instructions are like reading a rock...pointless.
    Something is wrong when it takes me longer to do an EFK than it does a timing belt....6 hours and I'm only halfway done with this confusing ass mod.
    Wings
    Carbs
    Titaniums
    Feb 17 2008
    Ottawa Ont.
    Because we are talking about two different trigger methods. a ground trigger via the thermostat sensor, and a 12V trigger via the AC fan wire.
    Dec 10 2006
    Wisconsin
    Would it be possible for you (or someone else) to slowly talk me through the wiring assuming I know nothing about the 2 ways and or what a "ground Trigger" is? I have the car apart, a relay with 5 wires and VAST's "instructions" aka Charmin in front of me. I've learned the hard way that these are not color coded though that would have been the customer friendly way of doing it. I've read several other posts about people not understanding these instructions and yet I have found no updates or pictures with how to really do it.
    I'm sure the 2nd time I do this it will take 10% of the time this first one took.
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    I want to have the fan come on with the AC and when the temps get to 95.
    Wings
    Carbs
    Titaniums
    Feb 17 2008
    Ottawa Ont.
    ground trigger then, as Jay describes.
    Dec 10 2006
    Wisconsin
    sigh....
    So are VAST's instructions wrong?
    Could you please, please, please walk me through it because here is what I think I am seeing /Reading:
    there are 2 ways that the fan will come on. One is when the AC is turned on and another is when the coolant is at or above 95 degrees.
    In order to do this it needs to be connected to both the AC fan AND a "T" wire or "ground trigger?" needs to be ran off of the fan wire. This will do the 95 degree part.
    The AC fan part will be triggered by the AC being turned on and to do this #86 needs to be tapped into the AC fan.
    #30 needs to be ran to the fuse holder which then goes to the positive terminal of the battery.
    This leaves me with 87a. A Blue wire in the middle of the relay that doesn't go to anything.
    I also have no real "ground" as I know a ground to be.
    So where am I derailing here?
    Wings
    Carbs
    Titaniums
    Mar 08 2007
    ct
    87a doesnt get used, sounds right the way u said it.You hook terminal 86 to battery +. Then tap into the brown green wire and run that to Terminal 85, thats the part i got confused
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 08 2007
    ct
    the brown green wire is from the ac fan?? im gonna rewire it right now it was dark so i couldnt see colors im gonna look now
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Dec 10 2006
    Wisconsin
    Where is the unit grounded then? And if #86 is ran to (+) battery then what do you do with #30 that VAST says to run to (+) battery?
    Wings
    Carbs
    Titaniums
    Mar 08 2007
    ct
    30 is the main power its fused to the relay. 86 can goto the foglight switch for power for instance like i had it. the other way of doing it i cant find a brown green wire that goes on and off with the fan im confused on that part
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Nov 10 2006
    minneapolis, mn
    Has anyone hooked it up (like above) and then to the fog as a manual override?
    01.5 B5 S4 - EPL Custom Stage 3, ER IC's, Aquamist HFS-1, AWE Downpipes, Borla Cat Back, Vogtland Coilovers, H-Sport Front & Rear Sways, AWE DTS, 710N Diverter Valves, RS4 Clutch, lightweight flywheel, Alcon's 6-piston, 18" OZ's, V1 Hardwired.
    Mar 20 2008
    Italy
    I have hooked it up per JHM instructions and then to a switch as a manual override. It's not the best way to do it imho.
    Doing so, the fan will kick in everytime you start the climate control (even at 100+mph, when it's not needed at all). Moreover, the aux water pump will kick in with the ignition off every now and then....with no apparent reason (even when the car is cold).
    I added the manual override switch to solve these issues. But it's not ideal.
    The best way to wire a EFK up is to use a thermoswitch, REVOTEC in the UK do some nice units imho ;)
    HTH
    RS4 B5
    Apr 07 2011
    Home of the mighty beaver
    This ^ I have to hit the "econ" switch and kill the AC in order to have the stupid fan turn off. Not the best way, but i do like it kicking in when i park the thing and the th thermostat triggers it.
    Nov 10 2006
    minneapolis, mn
    Thanks for your responses. I would think there would be a way to do this properly. Anyone else have better luck? TIA
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 30 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    Yes, the only problem with wiring it that way is that it's always on when the A/C is on, which does suck because you don't need it running on the highway. I thought of finding a way to wire it up to a temp switch or something that would shut it off once you were on the highway. I have noticed the aux pump kicking on every now and then, but it's only for like a few seconds and doesn't "hurt" anything or annoy me. The nice thing about wiring it up this way though is that if you just finished running the car hard and it's still warm the electric fan can actually come on when the ignition is off to help cool the motor down. Other than that it comes on when the A/C is on or when the car hits a certain temperature with the A/C off. Does anyone know what the blue wire is supposed to be for? It seems like it's actually a power wire. Mine is just wrapped in heat shrink and tucked away.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Mar 20 2008
    Italy
    I bought this, which can be installed in the top radiator hose:
    http://www.revotec.com/details.asp?ID=454
    Never got round fitting it as my EFK has blown and i've reverted everything back to stock ;)
    However, i thing that is the best wiring option out there for a EFK.
    RS4 B5
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    If you are removing the front fan couldn't you just clip the plug off that solder it into new fan and it would essentially take it's place?
    Sent from my iPhone via Tapatalk
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Nov 08 2007
    Lake Tahoe, CA/NV
    also wouldn't this enable the fan to be run at low speed when in after run mode rather then at full speed like when its wired to a relay. Is the Vast/JHM fan motor able to be run at half speed like the stock front fan is?
    Current Rides:
    @audijedi
    Established Member Two Rings crc364's Avatar
    Feb 11 2011
    GA
    ^I think it would do this, but am curious if anybody knows from experience.
    Nov 08 2007
    Lake Tahoe, CA/NV
    I did it. It works great!
    Current Rides:
    @audijedi
    Veteran Member Four Rings LowA4's Avatar
    Aug 04 2007
    00 S4, 01 Allroad
    Gardnerville, Nv.
    Doing this today or tomorrow.
    C5 RS6
    Stage 3 b5 S4
    8P A3 quattro
    B6 usp A4
    C5 Allroad
    Nov 30 2010
    Des Moines, IA
    Quote Originally Posted by Korben007 View Post
    It seems like wiring it that way would delete the purpose of doing the EFK setup. It wouldn't be able to run at full speed.
    - Cody T.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Y Would it not run at full speed because of using the AUX fan wires......
    Nov 30 2010
    Des Moines, IA
    Quote Originally Posted by *Blue-Angel* View Post
    I took it in the sense that he wired around the relay and just used the aux fan wiring without the relay. It shouldn't be able to run at full speed, or that I would forsee issues with blowing fuses without the relay being used.
    - Cody T.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by The_Auto_Tech View Post
    I would think the same... plus I would want to risk blowing up my fan controller for it...
    My high flow Spal fan from VAST pulls A LOT of current, that I know for sure... far more then the little aux fan.
    Sep 11 2007
    Tampa, FL
    That fan is already relayed so you wouldnt need the one from VAST if wiring it that way. I have had mine set up that way for a very long time and not problems. It runs geat that way. Does exactly its job as designed.
    Jan 29 2009
    you're running the high flow fan through the OE Aux fan wiring/fan controller?
    I know it's probably much to ask, but I'd love to see a vid of the can coming on and running @ high speed with that setup. I highly doubt the fan controller was designed to bear that kind of load considering the dinky fan that was originally on the circuit (aux AC fan).
    Sep 11 2007
    Tampa, FL
    I would if my car were running. But its down for the moment installing some bits and pieces.
