Results 1 to 6 of 6
    Active Member Two Rings actac95's Avatar
    Feb 26 2008
    '02 Ducati Monster 620
    Kansas City
    PLEASE HELP!!! My Symphony II won't budge..
    I have the removal keys inserted and a couple of them keep popping out when I pull, but even when I have all four of them in place, the thing doesnt move. Does anyone have any ideas? Can I get at it from the sides of the footwells? How do those panels come off? Any help is appreciated.
    Tom
    Senior Member Two Rings fapodaca's Avatar
    Dec 03 2007
    2014 AUDI RS5, 2013 GMC SIERRA, 1989 BOX CHEV
    DISCOVERY BAY
    Re: PLEASE HELP!!! My Symphony II won't budge..
    Insert The Keys And Try Wiggling It Out Buy Gently Pulling On The Cassette Slot, And Try Pulling The Keys Inward While Pulling Out.......
    Freddie Apodaca J.R.
    East County European AutoWorks
    Veteran Member Three Rings bigmerle's Avatar
    Jul 27 2007
    2001 A6 Avant
    Annapolis, MD
    ^x2 thats the way to get it done...had the same issue but just gave the cassette deck a lil stinky pinky action ;)
    01 Tornado Red A6 Avant.....Work In Progress.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by actac95 View Post
    Tom
    I had the same problem last night (pulled mine to replace with an RNS-E!).
    I removed the woodgrain trim surrounding the hazard switch (used a heavy paper clip and bent it a quarter inch to make a hook, tuck behind the woodgrain and pull straight out). With the hazard trim removed you can CAREFULLY pry on the metal case of the Symphony unit (be carefull not to pry on the edge of the plastic face plate) and you should be able to wiggle it out.
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    You are sure they are pressed in all the way until they click? I usually press the end of it towards the outside as I pull so the part inside by the radio is pushing the lock in all the way. This really shouldn't require anything special. The way the radio is held in is ridiculously simple technology.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Feb 26 2008
    Kansas City
    Ok, thanks for the suggestions but this S.O.B. aint coming out. I'm even possibly sacrificing the cassete player and using small hook trying to pull it out. I'm thinking the tabs are screwed up. if I take off the side panels of the center console, can I get to the sides of the radio? How do you take off the side panels? Thanks!
