Originally Posted by
04A6SLine
how good is the V1?? top of the line??
I feel it's about the best around - have one in every vehicle I own.
I recently tried one of the Passport SRX units (in a Cayenne Turbo - yuck!) and found it to be good for one thing - the laser shifting. It's quite funny to see the cop look down at his gun with this puzzled look. (twice!)
I feel that the V1 outperformed the SRX in every aspect of radar detection didn't false out at spots that I know will set them off near as much either. The SRX was probably 3:1 for falses in known hit areas.
I also didn't like the SRX not being able to point to the source. Once you get used to that aspect of the V1, it's hard to not have. Once again, more points for the V1 over the SRX.
I don't have any experience w/anything other than these two units, but from everything I've read, they're pretty much top dogs of the radar detection world, so I feel I'm comparing apples to apples.
For those that may be trying to install a V1 (or any unit, for that matter) into your Audi, pull the fuse cover panel, pull out a test light and check all the empty fuse sockets. One side will never supply power - that's the side that goes on down the line. The other side of the socket will (generally) either supply power all the time (unswitched) or when you turn the key. It allows you to insert a spade plug and not have to splice into any wires or try to stick wires under a fuse blade.
I can snap a few pix of both the RS 6 and R8 installs if anyone wants.
