Results 1 to 11 of 11
Thread: help!!!!
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    help!!!!
    So I was heading to a wedding yesterday and stopped by the store to grab a hallmark card. I went outside to the parking lot and started up the car and it seemed to idle really rough. I started driving it and the CEL came on and the car was driving very sluggishly. It wouldn't let me rev beyond 2500-3k rpm without seeming like it was choking out. I pulled aside and the car was idling very rough, around 2kish rpm.
    Based on the symptoms, what do you guys think it could be? I'm thinking it is the coil pack but I just need confirmation.
    Thanks for the help, fellas.
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Re: help!!!!
    uhmmm coil packs?
    hopefully thats what it is, if you have an autozone nearby or an advance auto then borrow their obd II scanner... how many miles? what motor and year?
    Sep 27 2007
    Boston, MA
    Re: help!!!!
    Quote Originally Posted by gmen08 View Post
    uhmmm coil packs?
    2004 1.8t tip with about 77k miles.
    Will the OBD II scanner indicate which one is the failed cp?
    Feb 05 2008
    Waterloo NY
    Re: help!!!!
    well i would lean towards the coild packs, uhm how long have you had the car? do you have the service history?
    Feb 05 2008
    Waterloo NY
    Re: help!!!!
    i would think that it would say somthing about a cylinder misfire for a certain head...
    Feb 05 2008
    Waterloo NY
    Re: help!!!!
    ik my moms taurus had a cracked spark plug wire and it shook and ran terrible, i hooked up my scanner and it read cylinder 2 misfire detected..
    Sep 27 2007
    Boston, MA
    Re: help!!!!
    thanks a ton. i will have to wait for tomorrow to do the fix. will audizine have this part in stock or will i have to run to the stealership?
    Feb 05 2008
    Waterloo NY
    Re: help!!!!
    i take it you meant autozone? lol anyways they should have, but ask a few guys from around here what they suggest, im not sure of the quality of the autozone/ advance auto, or what ever parts store you have would be, i mean you can always get a price from the stealership, and i would say if its less that 35 dollars then it wouldnt hurt to just get them from there... if you have the money i would suggest that you get al four brand new and replace them all, and if you have the extra time to wait then you should check out ecstuning.com for a set of 4 coil packs bremi i do believe they are around 120 dollars for all four... good luck man!!
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Re: help!!!!
    Sounds like coil packs for sure. Not sure if Autozone or those type of places carry them but like stated above get 4 of the revised coils and replace all 4. Its a good idea to have some spares in the trunk at all times incase this happens again on the road. I bought mine at ECS as well but considering you need them now go to the dealer.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Feb 05 2008
    Waterloo NY
    Re: help!!!!
    true^^ they will be quite a bit more exspensive probably but hey you need them so...
    Senior Member Three Rings BlaQ_B6's Avatar
    May 20 2008
    02' a4 1.8tQ
    Jersey
    Re: help!!!!
    Is your CEL flashing? If so then it's definitely a coil pack issue. Like others have said, replace all 4 cause the others are likely to follow suit.
    02' A4 1.8TQ
    Clear Cornered - Blacked out Grills - Stealth bulbs - 6000K DDM HID Kit - Independent Fog Mod - Debadge
