Results 1 to 20 of 20
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    DIY - Reset Service Reminder (w/out VAG COM)
    I learned how to do this yesterday, so enjoy!
    1. Place key in the ignition (leave it in the 'OFF' position),
    2. Hold down the 'WRENCH' button directly above steering wheel column,
    3. While holding the 'WRENCH' button, turn key into the 'ON' position (do not start the engine),
    4. Let go of the 'WRENCH' button, and quickly press the '0' button.
    That will reset the service reminder to the standard 5k interval.
    Dec 21 2007
    Romania
    Re: DIY - Reset Service Reminder (w/out VAG COM)
    Thanks !
    Feb 13 2004
    04 audi a4 1.8t ultraspor
    woodlands
    Hey that's awesome, I'll give that a shot tomorrow.. thanks!
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    Quote Originally Posted by mishu28 View Post
    Thanks !
    x2
    Senior Member Two Rings geoshu's Avatar
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    Interesting it reset mine to 9k
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Thought i would give this a little bump.
    Good thing to know, just reset mine
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I learned how to do it from my owner's manual.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Quote Originally Posted by kwimberly View Post
    lol basically..
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    May 21 2007
    Florida
    welcome to the owners manual...spend some time, take a look around lol
    2018 Navarro Blue Q5
    Jun 21 2008
    I read the manual through and through, and never read that. That's my fault guys, sorry.
    Will read more thoroughly before posting!
    May 03 2008
    Orlando
    Quote Originally Posted by 04b6sport View Post
    Hey - at least it's on the Internets now so if someone searches for it they'll find your post...
    I accidentally hit the CHECK button when I was going about 30 mph the other day - it set a warning tone that goes off every time I hit 30. To reset, simply hold CHECK for a few second when going between 0 and 3 mph...
    Kevin W.
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    ^^ You can hit check at any speed above 3 mph and it should warn you with a tone everytime you go over that speed. Pretty handy on long drives for those who can't afford any more speeding tickets! Press and hold the check button to cancel.
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Thanks, because you know how everybody loves to read the manual first !
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Registered Member Two Rings OhioA41.8T's Avatar
    Feb 22 2009
    03 Audi A4 1.8T Quattro
    Columbus, Ohio
    Good to know now. I ordered a book the other day to read up on everything. Why do people keep those books and not keep them in the car?
    Jun 28 2014
    MA
    5+ year old thread...sorry. But this doesn't work for me on my 04... Tried it a million times.
    Apr 15 2014
    Ottawa/Gatineau Canada
    yup.
    you can change the interval distance with a Vag Com
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Established Member Two Rings Ji99a's Avatar
    Jun 18 2014
    BC, Canada
    Quote Originally Posted by Luxus Panzer View Post
    yup.
    Only way to change the interval is with a Vag Com? When I reset mine the interval is "Days --- Mileage ---"
    03 A4 1.8t Quattro
    FMIC, CAI, Borla Exhaust, Vogtland Coilover, H Sport Swaybars
    (Some of this stuff was the previous owner so I'm trying to figure out what he used )
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by Ji99a View Post
    Drive it for 500 kms and a distance and date pop up based on your driving it calculates a distance, at least mine does
    Apr 15 2014
    Quote Originally Posted by seanf86 View Post
    this
    Aug 26 2005
    this
    This is only the case for Canadian, RTW and European Audis. A4s in the US don't have variable/extended OCI enabled in the instrument cluster. Resetting the original 10K miles/1 year OCI requires entering specific values in a certain order in the IC adaptation channels, requiring VCDS, or VAS factory tools.
    Vorsprung durch Technik
