Results 1 to 13 of 13
    Jan 04 2008
    Montreal
    S4 suspension on A4
    i have search but got nothing good.
    i know a S4 suspension will bolt to my A4 but will it be jack high or lower like a sport suspension ??? im sure someone will say because of the weight of the motor it will be higher...but i would like to see if someone did it and how it looked.
    thanks
    Dec 14 2006
    Halifax, NS, Canada
    Re: S4 suspension on A4
    wow you didn't search well then. It will make a 1.8T look like a 4x4 if you have a 2.8L it should work ok.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Don't do it. Just buy a4 stuff!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    you can run the s4 shocks.. Dont put s4 springs on an a4, it will just lift your car. This has been talked about A LOT on like 30 threads
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    actually i know someone who put s4 springs on a4 shocks and it lowered it by a finger or so. the s4 springs are shorter but stiffer
    Jan 04 2008
    Montreal
    you see...thats whats i was saying...some says it will be high...then someone says it will be lower ???
    did anybody realy did it ??? pictures ??
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    It'll be higher.
    Unless the springs off the donor S4 had been replaced with lower than OEM items.
    A stock S4 is actually HIGHER than a stock 1.8TQM.
    Just buy the correct springs for an A4, the only S4 bits you could run would be the dampers.
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Dec 14 2006
    Halifax, NS, Canada
    also no one said it would be lower
    NOW DEAD :(
    Jan 04 2008
    Montreal
    Quote Originally Posted by hiwords1 View Post
    anyway
    ok thanks now im sure it will be high...but another quick question...are the S4 shocks the same as the A4 sport ?? better with lowering springs ?
    Dec 14 2006
    Halifax, NS, Canada
    oh sorry... don't see how that is possible
    NOW DEAD :(
    Jan 27 2006
    Orange County CA
    Quote Originally Posted by kojiru View Post
    anyway
    No. According to Jason at Stasis, the S4 shocks are better. Not much, but still better.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Quote Originally Posted by ActiveMonkey View Post
    Correct and with say a set of H&R race spring it's a cheap upgrade and sits nice.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
