    Established Member Two Rings cleanandsimple's Avatar
    Sep 22 2006
    Lancaster, PA
    changing to electric seats
    My buddy has/had power leather seats in his a4 and will be getting rid of it soon. Therefore we swapped out my nasty manual cloth seats for the leather. Does anybody have a wiring diagram or know where to find one, so I can get my seat hooked up?
    Thanks Burky
    p.s. i did search but i could find much on seats
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: changing to electric seats
    i think 98.5's and up had the wiring there, cause they had the electric lumbar even if you had manual seats....(don't quote me on that). but i see you have a 97 so you will probably have to run power to them from somewhere else....75x maybe.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Jul 01 2008
    Minnesota
    Ive got manual leather seats but theres no power lumbar and theres no xtra wires down there for the seat. Wouldnt you just need to run power to it for it to work since the controls are on there already?
    Dec 23 2007
    Queens, NY
    Yeah I think you should and can run it to the 75 terminal its will give you power when your key is in that's all that matters. Good luck with that.
    1999.5 1.8t
    Carbonio - APR R1 Diverter Valve - TT Carrier - 12.3 One Piece Rotor - Stainless Steel Brake Lines - Podi Boost Gauge - More to come-
    Sep 22 2006
    Lancaster, PA
    Thanks a lot guys. I knew what I had to do but I was more looking for what color of the wire coming from the seat so I could hook power to the right one without burning up the motor. I don't think I worded my question right. Anyways with a little rigging up a fuse set up I figured it out.
