Results 1 to 24 of 24
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Who knows were this goes?
    I found this O ring laying on top of the block where the intake mani goes, the piece was laying right by the front passenger corner of the motor right before the power steering pump... I cant find a spot for it anywhere.. Now i have the motor back together and still couldn't fine a spot for it while building the motor. Heres where i found it, and it doesnt go where the water tube goes, that had a smaller oring on the tube it self when i installed it...
    Active Member Three Rings
    Dec 10 2004
    Seattle WA
    Re: Who knows were this goes?
    Those go between each rod.
    Dec 10 2004
    Seattle WA
    Quote Originally Posted by B528QM View Post
    Just kidding. Good luck
    Mar 14 2007
    michigan
    funny!
    Feb 29 2008
    Durham/NC/Southeast
    this reminds me of working at a Kawasaki/Suzuki shop back in the late 80s. Anytime anyone in the shop built a motor someone threw a piston circlip on the bench after they were done.
    Not to be a dick but between this and the oil pump tensioner questions you might be ready for some reference material for the 2.7.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    looks like the o-ring where the exhaust manifold connects to the turbo
    Mar 14 2007
    michigan
    I figured the oil pump tensioner out, i just wanted to be 100% instead of 99%... I never seen the install of the tensioner as the machine shop took the section apart before i got to glance at it.... The motors completely back together now, but before i still couldnt place this oring anywhere
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    In response to the thread title: That's what she said.
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    its a rubber o ring, correct? that go's between the accordian hose and stock airbox....
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    that o ting he has there is the size of a quarter not 3 inches man
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Mar 14 2007
    michigan
    Right i put a quarter in the center of the ring to show the size
    May 04 2005
    Connecticut
    my bad... didnt realize it was a quarter.... did you have k04's previously? could the the charge side(turbo to inlet) gasket
    2000 Audi A8
    Mar 14 2007
    michigan
    no stock
    Dec 06 2007
    Calgary, AB, Canada
    Looks like it could be a coolant seal. Have you checked the coolant temp sensor and after-run temp sensor?
    Mar 14 2007
    michigan
    the 2 green coolant temp sensors have rings on them, wheres the after run sensor? I never took any of them sensor off though...
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    O ring in the coolant lines under the intake manifold?
    Mar 14 2007
    michigan
    are u talking about the black coolant pipes if so they all have o rings on them... im thinking this was dropped at a shop or has been there since the factory.. I cant find anything remotely close to where it may go...
    Established Member Two Rings 2k1.5blacks4's Avatar
    Jul 02 2007
    2001.5 s4
    Birmingham, Alabama
    Quote Originally Posted by ThirdStrike View Post
    I help my buddy pull and brake down his motor the other day on his 2.7t a6 and that defiantly looks like the o-ring where the exhaust manifold connects to turbo. That was my first thought when I saw the pic. And the other metal thing on the table besides the quarter looks like a wire clip for the electronics in the lock carrier (or helps hold the hood cable to the lock carrier).
    Mar 14 2007
    michigan
    The oring going to the turbo is the size of a quarter?
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    I can't tell you what it is, but it does NOT look like anything internal. Check any sensors that will plug into the block, it looks identical to one of those seals.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Veteran Member Three Rings TalipseAWD's Avatar
    Apr 08 2007
    Stamford, CT
    i would of said coolant seal upon first guess.
    2000 S4
    May 04 2005
    Connecticut
    theromostate oring... final answer
    2000 Audi A8
    Registered Member Two Rings Knight_Rider's Avatar
    Feb 26 2008
    Go f*ck yourself!
    you figure out where that o-ring came from yet?
    I am Michael Knight, my car is K.I.T.T.- The Knights Industries Ten Thousand, my organization is F.L.A.G. I am powered by Garrett/Honeywell and GenerationJDM.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    What about the o ring that connect from the heater core hoses to the back of engine?
