Results 1 to 2 of 2
    Senior Member Two Rings jaykato's Avatar
    May 25 2007
    2009 Mercedes c63, 2001.5 Audi S4 Avant
    NH
    O2 Sensor Removal
    Giving the Wayne Angle Block O2 sensor spacer to maybe rectify my CEL on my labree DPs, but was wondering if there was any easy way to remove the O2 sensors without twisting the O2 sensor wire. Is the O2 Sensor hard to disconnect? Right now I am about to unhook the lower part of my downpipes, it's only three nuts and where it joins up with my catback, but I would prefer an easier solution.
    2005.5 S4 Avant Moro Blue.
    GIAC 93, Milltek catless downpipes, Labree catback exhaust, K&N, Bilstein PSS9, 18X8 BBS Diamond Black RE, 35% tint.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    Re: O2 Sensor Removal
    you can just use a 22mm wrench. should come out with a little power
