    Mar 27 2005
    The Cold North
    Jeremy - rear brake upgrade ?
    I am looking at two options and would appreciate your opinion. This is for my 2004 A4. Car is used as daily driver and a couple HDPE's a year.
    Option 1 is doing the larger StaSIS rear brake rotors and keeping the OEM caliper (cheaper & lighter)
    Option 2 is doing the B6 S4 rear calipers and vented rotors.
    My 2 concerns with the option 2 is i don't know how much different the calipers are and i am not sure of the A4 master cylinder is up to the job. also the b6 S4 rotors are heavier than the STaSIS upgraded rotor kit.
    Any info or guidence is appreciated.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Re: Jeremy - rear brake upgrade ?
    Quote Originally Posted by EBG 18T View Post
    Sorry for the delay....what are your reservations with just going with a fantastic kit as option1? That's what we have on our B7 A4 2.0TQM USP Avant and what we had on our B6 A4 1.8TQM USP Avant and love it.
    I see no reason to go with anything but it.
    LMK how we can help!
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Mar 27 2005
    The Cold North
    i was thinking option two since it is a vented rotor. Maybe keep the brake temps down? But i am sure option 1 is more than enough. I just want to do it right the first time.
    I will need new rear rotors here in oct/nov after the last HDPE. I wan't to get the max life out of these rotors. So i will just wait for the next STaSIS Sale and pick a setup at that point.
    thanks for you input and help
    2020 Chevy AEV ZR2
    May 27 2004
    Portland, OR
    I'm not sure how much of a reduction in brake temps you'll see with a rear vented rotor vs non-vented honestly.
    Anytime!
    Jeremy Williams
    Mar 27 2005
    The Cold North
    Quote Originally Posted by jeremy@matrix View Post
    Anytime!
    I wasn't sure either. Sounds like i should just keep it simple and just to the StaSIS kit.
    2020 Chevy AEV ZR2
