Results 1 to 3 of 3
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    idle/stall problems on 2.8 B5
    my car has been acting weird lately, it has 126k and the past 2 times when ive started it up it idles really roughly and then when i hit the gas the rpms just go to 0 and it stalls, also in between shifts before it just randomly stalls the ride is real rough and the rpms go all the way down to 0 between the shifts, once i let it warm up completely though it doesnt have problems, do you think it could be a fuel filter or fuel pump?
    thanks a lot,
    klaus
    Mar 30 2008
    woodbine, md
    Re: idle/stall problems on 2.8 B5
    i've actually had the same type of problems. my car has been idling really rough lately. idk what the problem is. i have 167k on mine so idk if the high mileage ties into the problem or not
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    From all the other threads I have been reading, it could be a vacum leak or your MAF needs to be cleaned.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
