Results 1 to 8 of 8
    Apr 15 2008
    Minnesota
    Tail Light Mod Gone Wrong
    i recently modded my new tail lights so that when i press the brake the fog lights come on as well. Great idea but one problem... getting the car out of park! using a short jumper wire i connected the brake light and fog light circuts but when i press the brake to get the car out of park it does not register that the break is even being pressed the only way to get it out of park is to turn on the fog lights then press the brake, then i am able to move the shifter then a brake light err comes up on my dash any ways around this??? or any other ways to do it? i am curious if anyone else has had this problem
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: Tail Light Mod Gone Wrong
    LOL.
    Sorry.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Registered Member Two Rings
    Jul 06 2008
    2001 Audi A4 1.8T
    I didn't do this mod. I personally think that the circuit is incomplete without switching on the tail fog lights....
    Dec 05 2007
    Check the link. Is that what you are referring to (trying to do)?
    Apr 15 2008
    Minnesota
    yeah that is the exact same thing i did to mine
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    well your first mistake was buying an automatic :P
    id say recheck all your solders and make sure the connecting wires arent grounding to another circuit. if that doesnt get you anywhere, try reverting back to stock (cut the wires) and see if it still does it. all else fails you can start messing with the brake light switch wiring under the dash. hope this helps.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    You have your fog light still hooked up? Discconect the fog light power and the ground and hook the wires up and than try. I personaly didnt do this mod but i'm sure that you cant have power comming from both ends. Be careful because this can cause some wires to melt and than you are in trouble.
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    did you use a diode? or just the wire? i used a diode and i can still use my rear fogs as well, i dont have an auto, but using a diode is the correct way to do this mod
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
