Results 1 to 9 of 9
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Stern Snub Mount
    Love it. Install was cakealicious. It slid right on the shaft with no lubrication, all natural baby. Took me at the very most 45 minutes to install.
    No vibration at idle anymore, smooth crisp shifts, and another mod to add to the list.
    Thanks PureMS.
    Dec 08 2006
    Cincinnati
    Re: Stern Snub Mount
    Did you do it while you had the front of the car apart anyways (i.e. timing belt etc) or no? If not, did you pull front of car or use the method that involves removing the actual snub bracket from the engine?
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    I am also interested if the mount can be replaced without taking off the front end.. All of mines are worn out..
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Nov 19 2005
    WA
    Quote Originally Posted by erikas3 View Post
    Yes you can.
    You'll probably need some type of lube, and a pry bar.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Quote Originally Posted by ILoveT View Post
    lol
    2004 Subaru Impreza WRX
    Aspen White
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Just take the front off. It's so easy. Take your bumper off and you are 9 bolts away from getting the snub off.
    Don't be intimidated, a blind person with no thumbs could do this install.
    Aug 13 2007
    tru dat ^
    Aspen White
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    was the vibration caused by stiffer motor/tranny mounts?
    i installed stiffer tranny/motor mounts, i love them, but the vibration at idle is slightly there and but gets annoying with the A/C on. I'm going to play around with them tomorrow to see if i can get them to settle a bit more and if that helps with the vibration.
    i have a snub mount to install.. might do that tomorrow too. i thought it would make the vibration worse, which is why i haven't bothered to install yet.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    You inspired me, I have been meaning to do this for a long time. Can't beat $30 either. I haven't had time to test it out but it idles smoother.
    You have to be kidding me Audi, I can squeeze this thing together with one hand! Two compleatly different products.
    [IMG][/IMG]
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
