Results 1 to 13 of 13
    Registered Member Two Rings
    May 29 2008
    TRINIDAD WEST INDIES
    & R Sport Springs "front is way lower than rear" help
    running 19's on sline and springs were installed and the front is extremely low the space is less than 8mm and the rear is about 20mm. can anyone explain this ??? any feed back will be appreciated
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    Re: & R Sport Springs "front is way lower than rear" help
    honestly, i think springs are springs. you cant do anything about it. but i know everyone else is going to say it so i might as well..
    pics please
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Actually (in addition to pics), I think what everyone else is gonna say, is what I'm about to say......two words bro:
    COIL OVERS!
    I know I know, sometimes people don't have enough $$ for CO's, but if you're at all able to save up for 'em, be patient and don't go for the first option you can afford.
    Hopefully someone will know how to fix your current parts, but if you can't get a solid answer, I'd sell the springs and try to put that towards CO's. My 2 pennies.
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Quote Originally Posted by a4sdaride View Post
    Are they for your car? They might be for a A4 that has a lighter engine. Therefore your heavier engine makes them sag too low. What's the ride like?
    I was reading last night they should lower front by 1.5inch and 1.4inch rear or something like that.
    | APR KO4 | APR TP | APR FUEL PUMP | CARBONIO | AWE CBE | S4 DOORBLADES | BBS Ch | TINT | KW V1 | BSH PCV STAGE II | HOTCHKIS F/R SWAYS |
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    Mine looks like that as well. I am pretty sure that they are the same springs as what I got with my cup kit. I really wish the rear came down lower. They should settle a bit, but not much.
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Nov 12 2007
    Grand Junction, CO
    CO's the way to go. Or shocks and springs combo. SPrings alone...good luck buying new shocks in 10,000 miles. By the time you're done, you going to have spent enough money to buy coil's/shock + spring + installl.
    May 29 2008
    tks ...odered the coilovers , KONI 1150 JB at performance cafe said these are the exact same as the stasis street sport and it was a bit chear $995 so hopes this solves my problem and in about 2 weeks i'll ALL LOWERED
    tks again
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    H&R springs are like that in all of their applications.
    They are better suited for the enthusiast who seeks improved handling and not "the perfect stance". If you wanted better handling and a better looking stance you should invest in a set of coilovers.
    Feb 16 2008
    Honolulu, HI
    Yeah, that's what I was told about my cup kit. It puts more weight over the front, since my car is FailWD and the sport cup kit set of springs and shocks is only for front wheel drive audis
    Veteran Member Four Rings gpxluke's Avatar
    Feb 14 2006
    Vancouver
    Yeah the front is lower than the rear...but it's not that big of difference in between though...i have about 3/4 finger gap at the front and 1 finger gap at the back...I am running shocks&springs though
    Jun 02 2008
    new york
    you have to let the springs seat properly before have a panic attack. give it 2 weeks.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Quote Originally Posted by gyroscope View Post
    You forgot to mention that a "better-looking stance" would also probably offset whatever handling improvements you could have gained by installing coilovers.
    One way you might be able fix this is with a properly setup alignment.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Feb 29 2008
    Quote Originally Posted by Erocko View Post
    ...FailWD ...
    -- Quattro owns!
