Wheel details: Momo M1 Chrome 9 spoke Aluminum wheels 19X8.5, Offset 38mm, Bolt pattern 5x112 center bore 57.1 These wheels cost over $600.00 each when new.
Wheel 1 is in perfect condition.
Wheel 2 is in perfect condition.
Wheel 3 has a very small chip on the outer lip about the size of a dime.
Wheel 4 has a small section of chrome peeling and has two structural cracks on the inside lip. These cracks have been professionally repaired with aluminum welding and are not visible from the front of the wheel. The previous owner of the car is who had the wheel repaired and he drove for thousands of miles on the repair with no issues.
Tire details: Bridgestone Potenza RE050A 255/35-19 Tread 140 Temp A Traction A
2 of the 4 tires have 70 % tread life remaining. The other 2 tires have about 50% tread life. These tires sold for $280.00 each.
I took these wheels off my recently acquired 2003 Audi RS6. I want the car to be completely stock so I purchased a set of OEM wheels.
I am assuming since my car is based on the A6 that these wheels and tires will fit other A6’s.
I also believe these wheels will fit the A4, Passat and Jetta but I would imagine that you would need smaller tires.
There are also other brands that use the same bolt pattern (Mercedes for example) but you would need to change the center bore rings.
The original cost of this tire and wheel package was over $3600.00. I am moving so these must get out of my garage. $600.00 takes all 4 wheels and tires with lug nuts.
Call Jim 602-826-1384. I prefer local pick up but will ship for more $$$
Link with photo's
http://web.mac.com/jimsmithsemail/Site_2/Photos.html
