Results 1 to 2 of 2
    Account Terminated Two Rings
    Mar 12 2007
    2000 s4
    new england
    Major B5 S4 garage sale, oem and aftermarket parts
    Parts to sell - all for b5 s4
    OEM Parts
    Oem k03’s, 2 sets $100 / set
    Accordian tube $10
    Oem heatshields $40
    new style front lower c-arms (rears, the big ones) $75
    a/c compressor $100
    Hitachi MAF housings cheap
    hitchi sensors used 50k $50 / per
    Crankshaft make offer
    full wiring harness make offer
    Driver’s side cylinder head w/ cams $200
    Dual mass flywheel make offer
    O1E transmission, works perfect $1300
    O1E transmission, very worn syncros, still shifts but is rough,
    it will need rebuild, great core $600
    APB block only, needs re-bore from timing belt failure nicks in cylinder make offer
    oem 99k miles exhaust manifolds $150
    b5 s4 valve covers $200
    Aftermarket Parts
    stasis motor mounts new $300
    asp track density trans mounts new $185
    01.5+ intake manifold port/polish by vast $450, ($300 worth of labor)light use, very clean
    ARP rod bolts new $150
    rs4 y-pipe with boots $750, light use, ceramic coated but flaking off a little bit
    brand new X1 intake w/ filter new $425
    MTM ~8.9 comp. ratio headgaskets new $220
    vast lwfw for b5s4 new $400
    bosch 044 fuel pump w/ basket, jsut needs a single fitting new $350
    3.5" custom catback exhaust $800
    oem rear main seal new $100
    oem timing belt / water pump kit new $300
    corbeau front driver seat bracket $60
    FOR SALE: 2000 b5 s4 transmission 6 spd O1E, works perfect!
    i have a perfectly working b5 s4, 6 speed 01E transmission. the trans was removed from a well running 115k bone stock car. car include oe flywheel and clutch if you want them. shifts great not notchy at all, nice and smooth, please email me with any questions or for pictures, asking 1300, willing to ship or can drive to meet up
    2 Kumho 711 tires 85% remaining 225 45 17 $100
    Campbell Hausfeld WS2800 welder $200
    Senior Member Two Rings Sammy7's Avatar
    May 03 2008
    2003 A4 Avant, 1985 320i Baur
    San Angelo, TX
    Thumbs down Re: Major B5 S4 garage sale, oem and aftermarket parts
