Results 1 to 12 of 12
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Is it possible to swap steering wheel controls on B7?
    I posted this question in a different section without any luck, so maybe someone here knows... I cannot get used to the awkward placement of the steering wheel controls with the volume being on the right and scroll being on the left. I wonder what kind of genius designed it this way. Do the UK-spec B7 cars have it on the opposite sides, and if so, is it possible to swap?
    Senior Member Three Rings atop's Avatar
    Jun 09 2008
    North Hollywood
    Re: Is it possible to swap steering wheel controls on B7?
    i was thinking the same thing on how is the buttons on the wrong sides.
    i would appreciate it if it was the way you want it.
    A T O P
    DUH! an Audi
    los angeles, CA
    i think it would be possible to swap, you would just need to extend the wires for the controls if needed.
    sounds like fun to do, DO IT!
    May 21 2008
    yeah, well I'm sure it could be done if the UK-spec A4's controls are placed differently than on the US models
    Jun 09 2008
    North Hollywood
    if u do it, update pics or success, etc.. thanks
    A T O P
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by ibiski View Post
    I actually like it this way. It's also good that Audi kept it consistent throughout their model range, as the MFSW controls operate the same on my Q7 and A3 too. Like anything else, with enough time and experience, your brain will adapt
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    I actually think they didnt keep it consistent, they just made a subtle change that drives me insane. On the steering wheel, the left roller button controls the track selection. In my 06, rolling the button upwards meant going to the next track, now its the opposite, it rewinds. I hate that! I was also wondering if it would be possible to rotate the button 180 degrees. Anyone actually tried this?
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    May 21 2008
    Quote Originally Posted by mksap11 View Post
    Consistent? Yes. Ergonomic? Not really. Most of the controls in your car are operated by your right hand, so why have a volume control there? Don't you change the track/channel more often than you do the volume? Speking of volume, my BT connect/disconnect chime got very loud for some reason and I can't find a way to turn it down. Anyone know how?
    Apr 06 2005
    Boston, MA
    To turn down the BT chime, push and hold the •))) button and roll volume control down.
    I actually adjust the volume far more frequently than I adjust the channel/track, so the way the controls are laid out work for me..but then again, maybe it's because I'm a southpaw
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Is this to adjust the volume of the ring for the car when you get a call or of the chime when the phone successfully connects to the car?
    The ringer on the car for when I get a call is ridiculously loud.
    The first time I heard it it sounded like an alarm and I thought someone was trying to steal my car while I was driving it. lolz
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    May 21 2008
    mksap11: thanks! I'll try it today. Raskal: it's for the chime. try adjusting the volume on your phone's "car" profile.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    instead of swapping wires on the steering wheel side it might be easier swapping the wires on the ECM side... or somewhere in between.
