Results 1 to 6 of 6
    Registered Member Two Rings lostinnd's Avatar
    May 14 2008
    Grand Forks, ND
    How to fix seized coilovers?
    I just bought my S and I need to raise it up. Its at 24.5" now and I would like to get it up an inch or so but my coilovers are seized. After a couple hours I was able to break loose one of the secondary locking collars but I have yet to be able to break loose one of the main collars. I have been soaking them in penetrating oil and tapping on them but they won't budge. IDK if it makes a difference but they are H&R coilovers.
    Any tips from the pros out there?
    Thanks alot,
    Matt
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: How to fix seized coilovers?
    Try taking a blow torch to em. Though I'm not 100% you can do that on a shock. Also, have you tried putting a wrench on it and hitting the wrench with a hammer?
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    If you are willing to try anything, How about some anti-seize/PB Blaster?
    Mar 23 2008
    seattle
    Put a flat head screw driver on one of the notches and hit it with a hammer in the correct direction. This is how I got my 4 year old KW varient 2's to bust loose after being at the same hight for such a long time. And TONS of PB blaster!
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    I had this problem. I just sprayed on wd40 and let it soak in for a few minutes, came back and hit it again with some more and let it sit for about 20 minutes. Since I lost the key, I just used a deep socked with a 6" extension in the groove then smashed on it with a hammer. Came undone perfectly.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Jun 14 2007
    2000 S4
    Connecticut
    i heard marine grease does the trick. i also have H&R coils, and im afraid to attempt to move it. haha it doesnt look like its moving ANY time soon
