Results 1 to 11 of 11
    Nov 13 2005
    Redmond, WA
    how can I disable the fog lights?
    I want to delete the Fog lights on my 02 A4 and was wondering if I can do it through Vag-com
    -Kalin
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: how can I disable the fog lights?
    For a 2002: scroll down to section 09-Elec. Ctrl. Mod. K1 – KWP1281
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    If you are Xenon the code for adaptation should be 00011
    If you are Halogen the code for adaptation should be 00001
    This will allow you to have the fog lights on without the headlights turned on. Assuming that is what your question was.
    -Doug
    Nov 13 2005
    Redmond, WA
    no i want to completely turn off the fog lights, because i removed them and now i get a light on the dash saying that my fog lights are out :(
    -Kalin
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Try closing the connection on the fog light wiring harness. This can be done by taking a piece of small wire and bridging the connection between the to electrical nodes connectors. It works for disabling the brake wear connection so I assume it would work the same for the fogs...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sorry. Your original post wasn't too clear to me. I apologize.
    Like Jordan mentioned, try using a wire to jump the two terminals. Kind of like how Jeff did for his windshield washer level sensor: http://www.audigeeks.com/forums/index.php?topic=862.0
    -Doug
    Nov 13 2005
    Redmond, WA
    ah ok will try that... and the brake thing also :D
    -Kalin
    Oct 22 2005
    Reppin the Mitten.
    Necro bump.
    But connecting the two wires?! That sounds like a recipe for a short, and blow a fuse to me...
    Anybody have any other better ideas for this, I'm thinking about wiring a resister of some sort to the fog lights to get rid of the error.
    Vince.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    ^^x2
    subscribed
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by vinny.dtw View Post
    Necro bump.
    Vince.
    Search again young Vin...you can use a resistor that has the same ohm value as the fogs themselves...
    Oct 22 2005
    Reppin the Mitten.
    Quote Originally Posted by 400HPA4 View Post
    I did search, and currently locating a resistor for the job, except i wanted to inform people that tying the two wires is a BAD idea.
    Nov 13 2005
    Redmond, WA
    i think that any small resistor would work. the circuit would only supply as much amperage for whatever is connected to it. in this case enough for the resistor and the icm would detect a user on the circuit...
    in theory it should be ok
    -Kalin
