Results 1 to 13 of 13
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    nitorgen ion tires??
    Just wondering if anyone is doing it? The dealership next to the one i work at is advertising it, i was thinking about doing it, but i havent really read anything to convincing about it yet other than it helps prevent the tires losing pressure as fast.
    On a side note, while i was test driving a car at work the other day i had a stupid thought, what if i filled my tires with helium?? I remember hearing about a guy at lockheed talking about it in aircraft tires as a way of weight reduction. For a split second it made since to me, than i thought, it wont do anything. Sorry i just had to tell my most recent "stupid" thought.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: nitorgen ion tires??
    nitrogen leaks out a very small ammount slower. and no helium wont make a difference :P
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Mar 24 2008
    Illinois
    thats what i realized after i thought about helium, right before i hit myself for the thought.
    But maybe i will try the nitrogen.
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Nitrogen decreases the chance of pressure fluctuations due to temperature. Constant tire pressure. Better fuel economy/tire wear.
    If you check your tire pressures on a regular basis, don't bother. It is more of a gimmick for lazy people.
    Atmosphere air is 78% nitrogen (or something like that).
    Apr 22 2007
    Riverbank, Ca
    Its also helpful for race cars, as it allows the tires to be at a more constant pressure, allowing for better grip and better wear.
    You see it in formula one.
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    The biggest advantage to nitorgen filled tires is the more constant tire pressure. It does not react as much to heat as normal air. It also leaks out slower than normal air due to the larger molecule size, however, it is not too much of a difference from what I have heard.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Veteran Member Four Rings seank's Avatar
    Nov 14 2006
    here
    I run it, but just b/c we have a tank at the shop for all the track cars. Definitely less fluctuation in pressure from temperature, but it is nothing to get hyped about.
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by andyrew View Post
    Ditto. If its a daily driver, it probably isn't a smart buy to use the extra money.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I didn't pay extra for nitorgen when I got my new tires in the fall of '07. I have to say the tire pressure stays very consistent even when it's really cold. Would I pay extra for this??? Maybe to get the consistent tire pressure.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Apr 22 2007
    Riverbank, Ca
    It costs money for the people to fill your tires with nitrogen so yes they normally charge you..
    Nov 14 2006
    here
    Lots of places will fill you up for free with nitrogen if you have your tires mounted and balanced by them.
    Mar 24 2008
    Illinois
    I read somewhere that it costs around $10 a tire for nitrogen.
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Costco has been doin it for years and its free. It's really nutin new.
