Results 1 to 12 of 12
Thread: Resetting dash
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    Resetting dash
    How do I reset the warning on my dash?
    Not CEL's...just the dipped headlight warning, low coolant, etc.
    TIA
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Resetting dash
    Um fix the problem and the CEL should go away IIRC...
    Jan 19 2007
    Columbus, Oh
    Re: Resetting dash
    Problem fixed haha
    I'm pretty sure you have to reset them...
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    Re: Resetting dash
    no need to reset just fix problems and cycle key
    2000 S4 IMOLA - CCW CLASSICS 18X9 18X10 - STASSIS TRACKSPORTS 700/800 - ASP DTS - STERN MOUNTS - 034 DP'S - ASP TRU DUAL - CUSTOM INTAKE/CATCH CAN - VAST METH - AEM WIDEBAND - RS4 INTERCOOLERS - JFONZ TUNED
    Jan 19 2007
    Columbus, Oh
    Re: Resetting dash
    By cycle do you mean turn it off and back on?
    Sorry for a dumb question...
    Jan 19 2007
    Columbus, Oh
    Re: Resetting dash
    You were right!
    I had a little brain fart.
    But, if I removed my fog lights, how to I keep the warning from staying on?
    (Rieger bumper and I cut out the fog mounts)
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Resetting dash
    Yes, fix the problem and turn off then turn on the key.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 21 2006
    Lakeland, FL.
    Re: Resetting dash
    Quote Originally Posted by RED1.8T View Post
    You were right!
    Plug in just the bulbs and tuck them under the bumper.
    I'm back bitches!
    Jan 19 2007
    Columbus, Oh
    Re: Resetting dash
    Easy enough.
    Is there any chance a resistor would work?
    Mar 21 2006
    Lakeland, FL.
    Re: Resetting dash
    Yes, just measure the resistance of the bulb and buy a matching resistor in the highest wattage you can get, usually about 10watt IIRC. And get the ceramic kind also.
    I'm back bitches!
    Jan 19 2007
    Columbus, Oh
    Re: Resetting dash
    Thanks alot!!!
    Mar 21 2006
    Lakeland, FL.
    Re: Resetting dash
    Word!
    I'm back bitches!
