Results 1 to 4 of 4
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    ? for transmission guru's
    I had my transmission rebuilt. They replaced the second gear, second gear collar, and second gear syncro. How does my second gear look?
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Re: ? for transmission guru's
    The 1-2 collars always lock up so that explains why that would be replaced. Out of all the trans kits I sell, the most common other parts to replace are 2nd gear and sometimes third gear. Not due to the gear itself but due to the front edge where the shift collar engages. Yours is definitely rounded and would be a definite replacement on a customers car and a borderline replacement if it was my car or if I was in a pinch.
    Think about all the times that 2nd gear grinded or crunched due to a worn synchro, that grinding is what rounds that out. So to all those who have a a grinding second you may not want to wait. Each time it happens it rounds off that gear. And that gear costs $490.
    Hope that info helps.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Sep 19 2006
    The Man Cave
    thanks jay! i was hoping you would reply.
    //NEVER FOLLOW
    Dec 06 2007
    Calgary, AB, Canada
    OP,
    The part you're looking for is in the 3rd pic from the bottom. At the top of the gear, there are those little teeth. They should have a sharp angle to them, yours look smeared and rounded, like Jason said.
