Originally Posted by
04QuattroTurbo
Brakes, tire pressures, uneven tire wear, balancing...steering wheel needs to be adjusted? Bent frame. Look like your rear is still off. Why is your toe off after when it was fine before?
Tire Pressures are all even. Maybe uneven tire wear because my front left tire is beyond showing wire (due to incorrect toe). As for Bent frame, I hope not, lol.
As for brakes, thats interesting. One thing I have noticed with my stock brakes and my current B5S4 caliper is that the passengers brake pads always wear faster than the drivers brake pads. Maybe a malfunctioning proportioning valve?
As for the rear toe, the reason it is off versus what it was, is because we [my friend who works at the toyota dealership and I] decided to set the right rear toe identical to the left rear toe. And the reason we could not set the left toe into the green area, is because the eccentric bolt would bottom out, before it would reach the green area.
02SILVANT
Did you get the Rial's put on?
No. I decided to use my current 18" wheels for the alignment, so they heads (for the alignment machine) dont scratch up my new wheels. Plus they just shipped out!!
